Dove C heads?
Barney
bigjohn2007
Dove C heads? Empty Dove C heads?
Post  bigjohn2007 March 4th 2012, 12:51 am
need part# for what you guys have used on these heads.spec on motor be 4.3 crank,6.8 rod,forged piston 60 over,cam will be custom from Lem.this be drag car so solid roller cam.it will be a project to have fun and learn so no need on it cost more than alum. heads,what better all that just helpful answer please.thanks
bigjohn2007
bigjohn2007
Dove C heads? Empty Re: Dove C heads?
Post  BOSS 429 March 4th 2012, 12:52 am
what comp ratio? head flow?
Post  dfree383 March 4th 2012, 12:53 am
what kind of power or et range are you looking for?
Post  Barney March 4th 2012, 12:57 am
Are you asking for a cam part #?
Barney
Barney
Post  bigjohn2007 March 4th 2012, 1:03 am
no guy they are stock set heads and i want put 521 need know spring,valve.retainers.etc.
bigjohn2007
bigjohn2007
Barney wrote:Are you asking for a cam part #?
No
bigjohn2007
bigjohn2007
Post  bigjohn2007 March 4th 2012, 1:05 am
dfree383 wrote:what kind of power or et range are you looking for?
600-650hp
bigjohn2007
bigjohn2007
Post  dfree383 March 4th 2012, 1:10 am
600-650hp
It will take some work on the DOVE-C's to get that and it will cost some $$$ especialy if you can't do the work your self.
You need to look at $$$ for the work vs getting some out of the Box SCJ Aluminum heads. I'm thinking that you'll find that by the time you get all the parts, machine work and porting work done, you won't be far off the cost of a set of Ford Racing heads.
I know thats not what you want to hear, but for a trypical fox body and 10.0 index you'll need to be in the 675-700hp range to give your self a little margin for weather and track conditions. and that get alot easier with good heads to start with.
Post  bigjohn2007 March 4th 2012, 1:16 am
already got good heads scj and lem already cut cam for 545 for me.would like to do a set dove heads thanks
bigjohn2007
bigjohn2007
Post  Barney March 4th 2012, 1:29 am
With D0VES it's more time than money and what you have the ability to do yourself. 2.19/1.76 valves work well,but plan on a lot of time in the porting, or money if you need them done start to finish by someone else. We USC Comp stuff on my D0VEs pretty standard stuff. Your cam will dictate what you will need. If Lem is doing the cam he will be able to hook you up with the rest of the stuff your gonna need.
Barney
Barney
Post  bigjohn2007 March 4th 2012, 1:32 am
Barney wrote:With D0VES it's more time than money and what you have the ability to do yourself. 2.19/1.76 valves work well,but plan on a lot of time in the porting, or money if you need them done start to finish by someone else. We USC Comp stuff on my D0VEs pretty standard stuff. Your cam will dictate what you will need.
what size cam was u runnig with dove head and what part num on your springs. thinking about checking Mad Porter out and do it myself.
bigjohn2007
bigjohn2007
Post  Barney March 4th 2012, 1:43 am
270/276 - 649/642 comp solid flat tappet930-16 springs, 611, or 613 locks depending on the valve you may be able to use 624 locks.
Barney
Barney
Post  bigjohn2007 March 4th 2012, 1:46 am
Barney wrote:270/276 - 649/642 comp solid flat tappet930-16 springs, 611, or 613 locks depending on the valve you may be able to use 624 locks.
thanks
bigjohn2007
bigjohn2007
Post  bigjohn2007 March 4th 2012, 1:58 am
what about guideplates u run raised,3/8?
bigjohn2007
bigjohn2007
Post  Barney March 4th 2012, 1:59 am
Yep 4838
Barney
Barney
Post  bigjohn2007 March 4th 2012, 2:09 am
what part # valves?
bigjohn2007
bigjohn2007
Post  Barney March 4th 2012, 2:18 am
11801ex/11822in
Barney
Barney
Post  bigjohn2007 March 4th 2012, 2:22 am
did u port your heads and if so just the exhaust side or what?
bigjohn2007
bigjohn2007
Post  bigjohn2007 March 4th 2012, 2:23 am
Barney wrote:11801ex/11822in
are they in jegs or summit so i take look?
bigjohn2007
bigjohn2007
Post  Barney March 4th 2012, 2:27 am
Manleys. Idk if they are in either catalog.
Barney
Barney
Post  Barney March 4th 2012, 2:29 am
bigjohn2007 wrote:did u port your heads and if so just the exhaust side or what?
Both, plus the intake manifold will need the same level of attention to meet your goals. The port work will have to be very, very, good to meet your goals. It won't be a gring a little here, and there deal.
Barney
Barney
Post  bigjohn2007 March 4th 2012, 2:55 am
good info
bigjohn2007
bigjohn2007
Post  bigjohn2007 March 4th 2012, 1:55 pm
anyone got pic of heads before and after porting?
bigjohn2007
bigjohn2007
Post  yellowhorse7 March 4th 2012, 3:50 pm
bigjohn2007 wrote:anyone got pic of heads before and after porting?
Can you weld?
yellowhorse7
yellowhorse7
Post  Barney March 4th 2012, 3:52 pm
Nope...have fun.
Barney
Barney
