598 SCJ Build
+23
Jetman
butterbean
Gary Blair
460bronco
theredcar
KEVIN S
61coon
norm
dirt_worker
1970 ford maverick
stanggt
68galaxie
darren
Barney
derek528
27 posters
Page 2 of 4
Page 2 of 4 • 1, 2, 3, 4
Re: 598 SCJ Build
Well we skipped last saturday because we ran out of parts. The pistons and cam showed up yesterday so we are going in sat and we should start making alot of progress on the short block. The cam we ended up with is a custom comp. 281, 296 duration @.050 113 lobe sep. Lobe lift is .470 on both lobes which is .813 with a 1.73 rocker.
derek528- Posts : 115
598 SCJ BUILD
Nice build "derek528", any progress lately? THNX MAVMANderek528 wrote:Well we skipped last saturday because we ran out of parts. The pistons and cam showed up yesterday so we are going in sat and we should start making alot of progress on the short block. The cam we ended up with is a custom comp. 281, 296 duration @.050 113 lobe sep. Lobe lift is .470 on both lobes which is .813 with a 1.73 rocker.
1970 ford maverick- Posts : 180
Re: 598 SCJ Build
Yeah, the block is fully machined, cleaned, plugged, and the cam bearings are in.. The heads were cnc'ed last week. Tomorrow we are going to pin fit the rods, file the rings, and hopefully assemble the short block. The crank is balanced and ready to go in. I'm ready to hear it run, And see what it does on the dyno. Hopefully It will be done by the end of may.
Re: 598 SCJ Build
The short block is now assembled. Cam is in, it's 3.5 degrees advanced. Next weekend we will assemble the heads. Pushrod lengths ended up at 9.050 intake, and 9.150 exh. Geometry looks good with the crane gold wide body rockers, we ended up with .830 gross valve lift, when measured off the retainer.
I did get some flow numbers. They ran the same cnc program on another set of heads. The customer decided to have them flowed. The only difference is that my heads have a 2.25 valve and the ones they flowed use the original 2.20 valve.
I don't have all the numbers, but the heads flowed 377 at .500, and 403 at .800 w/ 2.20 valves. I don't know what mine flow with the 2.25 valve, I'd guess slightly more. The exh ports were less impressive at 220 cfm without a test pipe. The bowls are pretty big on the exhaust, that hurts the flow numbers when not using a pipe, and they didn't have a test pipe handy to use for the test.
All in all I'm very pleased with the headwork, I think it's going to make pretty decent power.
Re: 598 SCJ Build
Just another update. We got the oil pump, and pickup tube on. We set the pickup/pan clearance. My brother made a crank scraper for me, it turned out pretty nice.
Re: 598 SCJ Build
getting closer, mocked up the valvetrain with got pushrods ordered, working on the intake now. About two more weeks should have it done.
Re: 598 SCJ Build
I have to thank Lem Evans, a lot of the parts used were supplied by him, his service was spot on.
Re: 598 SCJ Build
any updates ?
John Myrick- BBF CONTRIBUTOR
Re: 598 SCJ Build
Still working at it. It's close, it should be on the dyno in a couple weeks.
Re: 598 SCJ Build
It's finished. If all goes well, I will have dyno numbers by the end of next week.
Re: 598 SCJ Build
Sweet, Keep us posted.
Re: 598 SCJ Build
Nice looking job on the intake. have any pictures of the plenum?
dirt_worker- Posts : 535
Re: 598 SCJ Build
derek528 wrote:Here are a few
Looks good Derek,
Lot of hard work and welding, porting time. You might want to round your runner dividers more to keep the air on the walls the look sharp in the pictures.
Re: 598 SCJ Build
I knocked them over with a sand roll, they probably are still too sharp, but I was running out of steam by that point and settled for good enough. I'll probably do more to the intake some time in the future if I get bored.
Re: 598 SCJ Build
looks familiar......
Re: 598 SCJ Build
richter69 wrote:looks familiar......
I kinda modeled it after the small block manifold made by edelbrock for the sc1 heads
Re: 598 SCJ Build
derek528 wrote:richter69 wrote:looks familiar......
I have done two intakes like you have done, one was a victor the other a mafia the.
You can see mine in the proven build section, I will bump it up for you.
There is a video of it a couple of pages in.
Re: 598 SCJ Build
IDT-572 wrote:derek528 wrote:richter69 wrote:looks familiar......
cool I'll check it out.
Re: 598 SCJ Build
richter69 wrote:
Looks familiar lol. That started as a victor correct?
Re: 598 SCJ Build
mine is the TFS Blake did, I'll be honest my little 563 dont really start liking it until it gets over 7500 lol. I'm gonna make it a 588 this winter and more than double the nitrous I'm putting to it now........ it wont want to peak as high then lol.
Re: 598 SCJ Build
Shift it at 6k, it'll fly...richter69 wrote:mine is the TFS Blake did, I'll be honest my little 563 dont really start liking it until it gets over 7500 lol. I'm gonna make it a 588 this winter and more than double the nitrous I'm putting to it now........ it wont want to peak as high then lol.
» E4OD build reccomendations for a 79 f150... first transmission build, no ideah what I'm doing
» No rules BBF nitrous build - Let's build it
» 408/418W build... what would you build?
Page 2 of 4
