429 f150 swap
429 f150 swap
OK after reading the last couple days, I see to swap a 429 into my 79 F150 (400 np435 205 bla bla bla) ill need a diffrent flywheel setup. I have all the parts I need save a clutch set up. I Know from my learning not to go the 390 flywheel clutch and flywheel unless i want to build a spacer, so heres the question. If i get a flywheel from a pre 79 460 thats a 12"er will i still need a new clutch kit or will my old one from my 400 thats fairly new still work as it ought to be a 12" setup. i have seen so much jargon im slightly confused but im thinking this is my answer.....
barbatostan- Posts : 19
429F-150 swap
Well I'm not sure about that, but I was wondering if I could use the HD 429 flywheel that came with the Fire Truck motor that I am using for my 460 build?
motorhead- Posts : 75
Re: 429 f150 swap
I would think that the clutch you have would work on the new flywheel.
schmitty- Posts : 4538
» 460 SWAP INTO MY 94 F150
» 1978 f150 4x4 302 swap
» Some questions on 429 swap into 79 f150
» 1980 F150 4x4 Engine swap
» 98-03 F150 472 C-6 Swap - Mounts, Pan, , Headers, Plus ????
