Who is running a big sollid flat tappet cam?
kjett
bigblockfox468
mudtrucker
I have tried the "search" function with no luck. Anyways I remember reading a build post that I am almost sure was in the proven build section that used a big custom ground solid flat tappet cam. If this is you or you know which post it is or you are running a big solid flat tappet let me know please.
mudtrucker- Posts : 160
Re: Who is running a big sollid flat tappet cam?
mudtrucker wrote:I have tried the "search" function with no luck. Anyways I remember reading a build post that I am almost sure was in the proven build section that used a big custom ground solid flat tappet cam. If this is you or you know which post it is or you are running a big solid flat tappet let me know please.
Not sure if you're referring to me but heres mine:
https://www.429-460.com/t4799-my-build-my-fox-transformationlotsa-pics
Go to page 4 and cam specs are there. Any questions give me a shout or better yet give Blake (my engine builder) a shout he goes by IDT-572.
Hope this helps
You are the man!!!!!!!!!! Thanks thats the one.bigblockfox468 wrote:mudtrucker wrote:I have tried the "search" function with no luck. Anyways I remember reading a build post that I am almost sure was in the proven build section that used a big custom ground solid flat tappet cam. If this is you or you know which post it is or you are running a big solid flat tappet let me know please.
Hope this helps
mudtrucker wrote:You are the man!!!!!!!!!! Thanks thats the one.bigblockfox468 wrote:mudtrucker wrote:I have tried the "search" function with no luck. Anyways I remember reading a build post that I am almost sure was in the proven build section that used a big custom ground solid flat tappet cam. If this is you or you know which post it is or you are running a big solid flat tappet let me know please.
Hope this helps
n/p
How big do you consider big? Not every cam will work in every application. My cam is on the aggresive side, but it designed to work with my ported d0ve's. It would probably leave a ton on the table if I used it with my a460 heads.
kjett- Posts : 1169
I thought you were running a solid roller cam not a solid flat tappet. I understand that what is "big" for one combo would be be "small" for another. But the cam that Bigblockfox468 has is in fact on the "big" side of a solid flat tappet and is what I was looking for.kjett wrote:How big do you consider big? Not every cam will work in every application. My cam is on the aggresive side, but it designed to work with my ported d0ve's. It would probably leave a ton on the table if I used it with my a460 heads.
I am running a solid roller. My point was what is the rest of the combo to make it all work? Sometimes big to one person could mean moderate to another. All depends on application.
kjett- Posts : 1169
mudtrucker wrote:I thought you were running a solid roller cam not a solid flat tappet. I understand that what is "big" for one combo would be be "small" for another. But the cam that Bigblockfox468 has is in fact on the "big" side of a solid flat tappet and is what I was looking for.kjett wrote:How big do you consider big? Not every cam will work in every application. My cam is on the aggresive side, but it designed to work with my ported d0ve's. It would probably leave a ton on the table if I used it with my a460 heads.
If your going to run the cam Mike has you need to call me, it's not your typical solid flat tappet.
" barbwire" series..................not for the faint of heart.
Hope this helps
I remembered that but, I thought you meant BIG ... that is a pretty typical bracket race type camshaft.
Big is like what they used to run in Pro Stock years ago when they still ran flat tappets; something like 286/298@.050" with mid .700's valve lift,
I am running .649 lift not as big as the one that Bigblockfox468
» Running in a flat tappet cam.. opinions on procedure please..
» Getting ready for sat and Sunday race weekend
» Sbf flat tappet cam oil
» A460 heads with solid flat tappet
» 501 rebuild i have a flat tappet cam
