Brand X Ruff Running Help
Brand X Ruff Running Help Empty Brand X Ruff Running Help
Post  billandlori April 14th 2012, 8:53 pm
Our daughter in law bought a 1996 Camaro with the 3.8 last fall. The car is mint but it runs really rough sometimes.
I found the EGR actuator was broken and not seating so I replaced that. It starts better but still runs rough when it is in the bottom quarter of the tank, it seems to run fine when it is filled up!! Would this be a fuel pump issue or what???
Thanks for the help in adavnce. BTW, I already suggested selling it and getting a Mustang lol!!
Bill
Brand X Ruff Running Help Empty Re: Brand X Ruff Running Help
Post  dfree383 April 14th 2012, 11:01 pm
How about putting a ford driveline into?
Post  Larry T April 15th 2012, 12:12 am
that is about the same simtum my honda had.i had replaced all of the after the fuel tank filters with no resolution.one last thing was the in tank pump and filter so i said if im in their im replaceing both.the pump was good but the filter on the bottom of the pump was clogged badly.i cut the filter around the edge it had real fine silt dirt in it,the tank was clean though.
at first the car would act up around 1/4 tank,then about 1/2 tank.after it done it with nearly a full tank is when i got pissed and done the intank deal,no moor problems!
Larry T
Larry T
Post  billandlori April 15th 2012, 8:48 am
Larry T wrote:that is about the same simtum my honda had.i had replaced all of the after the fuel tank filters with no resolution.one last thing was the in tank pump and filter so i said if im in their im replaceing both.the pump was good but the filter on the bottom of the pump was clogged badly.i cut the filter around the edge it had real fine silt dirt in it,the tank was clean though.
Good info, thanks Larry!!
Bill
Post  hillbillyerv April 18th 2012, 12:26 pm
i would check the rubber line between pump body and outlet, split line will cause these exact condition Cool
hillbillyerv
hillbillyerv
Post  billandlori April 20th 2012, 6:53 pm
hillbillyerv wrote:i would check the rubber line between pump body and outlet, split line will cause these exact condition Cool
Thanks!! I'll check that out!!
Bill
