C-4 convertor question
C-4 convertor question Empty C-4 convertor question
Post  lghting94 April 26th 2012, 1:29 pm
Is there any way to tell which convertor spline a c-4 has without pulling the tranny? I am helping a buddy and he is getting ready to order a new convertor but doesnt know what to order.
lghting94
lghting94
C-4 convertor question Empty Re: C-4 convertor question
Post  ultimatelenny April 27th 2012, 8:26 am
Without actually counting the splines on the input, you can get the ID numbers off the case and find out what year it was manufactured. 1970 and later will have the 26 spline, earlier will have the 24 spline. Hope this helps a little
ultimatelenny
ultimatelenny
http://www.ultimateconverter.com
Post  lghting94 April 27th 2012, 10:38 am
OK I will look to see if I can figure out a year on it. Can a 24 spline c-4 be converted to a 26? If so what all parts would need changed?
lghting94
lghting94
Post  ultimatelenny April 27th 2012, 11:01 am
I believe so, as I am not a trans guy by any means, but I'm sure there will be someone along with more knowledge with them. I know you would need to change out the shaft and drum.
ultimatelenny
ultimatelenny
Post  lghting94 April 27th 2012, 11:04 am
Thank you for your help Lenny. I need to call you about the c6 convertor I got from you two years ago. I quit mud racing and now putting stuff in a fox mustang
lghting94
lghting94
Post  ultimatelenny April 27th 2012, 12:46 pm
No problem, however we can help.
ultimatelenny
ultimatelenny
Post  johndickjr April 29th 2012, 12:57 pm
lghting94 wrote:OK I will look to see if I can figure out a year on it. Can a 24 spline c-4 be converted to a 26? If so what all parts would need changed?
i just went threw this same thing...you can change to a 26 spline if itis a 24..but obt its a hassle..you have to changed the internal parts also..easier to just get the correct converter to start with..pull tranny out and count splines..easy
johndickjr
