Convertor question
Convertor question Empty Convertor question
Post  Tore January 1st 2014, 3:56 pm
I bought a 61 Ford wagon and somebody put a C4 in and it needs a rebuild. I want to swap it out with a C6 I have here. Are the convertors the same for a C6 and a C4?
Also I have an old GER convertor from years back that worked great for the street. I had it behind a very strong 460 and it stalled about 3500 rpm.
Any idea what it will stall behind a low compression 73 460???
Thanks Tore
Tore
Tore
Convertor question Empty Re: Convertor question
Post  richter69 January 1st 2014, 6:49 pm
input shafts are different, you dan stick a c6 converter in a c4 if you use the spline adapter, wont work the other way without cutting converter open and swapping the turbine.
Post  Tore January 1st 2014, 7:56 pm
[q Thanks Tore
uote="richter69"]input shafts are different, you dan stick a c6 converter in a c4 if you use the spline adapter, wont work the other way without cutting converter open and swapping the turbine.[/quote]
Tore
Tore
Post  bbf-falcon January 1st 2014, 10:21 pm
Tore,I probably have one for c6 if you need one.
Post  Tore January 1st 2014, 11:50 pm
Thanks Rick I was wondering if anyone had a guess what this convertor would do for a low powered 460 before I put it in.
Thanks Tore
Tore
Tore
Post  bbf-falcon January 2nd 2014, 12:25 am
Tore,jmo,but for what you are going to use that AWESOME wagon for,I would go w/stock converter. A 3500 would build unneeded heat that your flood dosen't need.
Post  Tore January 2nd 2014, 1:05 am
That's my new Company Car. Glad you like it Shocked . I need to find another one for a few parts.
Tore
Tore
Post  maverick January 2nd 2014, 8:01 am
Need better pics of that wagon. Cool
Post  Tore January 2nd 2014, 9:36 am
This car is a 50 footer. Its not real cherry. But its pretty much complete and all the trim is there. The underside is very solid.
The interior needs a redo. I want to convert over to a 9 passenger so I have to find a donor car with the extra seat.
I am going to use it as a cruiser. A lot of potential.
Tore
Tore
Tore
Post  bbf-falcon January 3rd 2014, 11:40 pm
That's a SUEEEET ride Tore,Cool factor is off the chart imo. Cool
Post  Tore January 3rd 2014, 11:50 pm
I already knew that Rick you didn't have to tell me that! Cool Cool Cool
Tore
Tore
Tore
Post  whitefield January 3rd 2014, 11:51 pm
Tore wrote:This car is a 50 footer. Its not real cherry. But its pretty much complete and all the trim is there. The underside is very solid.
Tore
Nice cruiser ! All of your cars that I have seen of yours are nice !
whitefield
whitefield
Post  Tore January 4th 2014, 1:19 pm
Tore
Tks Tore
Tore
Tore
