oil filter bolt
oil filter bolt
OK got a quick question the oil filter bolt on a d9 block is circled at the base of motor,instead of being hexed to unscrew it.(need to make it shorter)is this a pressed in bolt.What's the easiest way to remove it. THANKS Dave
dave d- Posts : 809
Re: oil filter bolt
It's not pressed in.
Look inside and see if it has a hex for an Allen wrench. Should be 7/16"
If not, you can use an internal pipe wrench or get 2 thin jam nuts and lock them together where the filter screws on
Re: oil filter bolt
some of them can be tuff to get out.
» Don't they use a copper washer under the attaching bolt on a oil filter adapter?
» External Pump Oil Pan for Fox, 6-bolt Valve Covers, Moroso Remote Filter Mount
» Best 4-Bolt caps/DOVE-A 2 Bolt
» 4 bolt main conversion? Or 2 bolt main stud girdle?
» Rod bolt and cam bolt torque?
