Don't they use a copper washer under the attaching bolt on a oil filter adapter?
Was noticing on bench that it was just bolt to aluminum and didnt see what it once had. But copper washer I felt ive seen before on a oil adapter in a pic.
ED468- Posts : 200
Re: Don't they use a copper washer under the attaching bolt on a oil filter adapter?
http://www.460ford.com/forum/showthread.php?t=158260 I hope this helps some. I wish I could help more, but I have never used one. It looks like you need something for a seal no matter what style adapter you have.
supervel45- Posts : 4499
washer oring
Its off a 85 f350 four wheel drive, have to call Ford I suppose. A nylon washer like what I buy for holley power valve would be nice to find also..,Thanks..,ED
ED468- Posts : 200
Cost..... Copper is expensive
The long hollow bolt that screws through the F-250's remote oil filter adapter is available with either
Which sealing method you have is dependent on bolt/adapter combo. If you have a 1985 F-250, then you probably have the right-angle oil filter adapter that uses the gasket directly beneath the bolt flange.
- an o-ring located near the top of the hollow bolt's shank but below the bolt's flange (o-ring seals between the bolt shank and the aluminum right-angle adapter's thru-bore), or
- a gasket directly beneath the hollow bolt's flange (gasket seals/gets sandwiched between the hollow bolt's flange and the top of the aluminum right-angle adapter)
Are the gaskets still available from the Dealership?
ED468- Posts : 200
» 3/8 ARP 200,000 psi cam bolt and thin hard washer ,is the washer to thin
» Timing Gear/cam retaining bolt
» Head bolt torque and Copper gaskets
» oil filter adapter?
