oil filter adapter
strokedmyford
oil filter adapter
has anybody had any bad experiences using an oil filter adapter. I hate like heck to use one but on my new build the steering shaft in the way of the filter. The one I was going to use is the ford M-6880-A50. pics are on the other site http://www.460ford.com/forum/showthread.php?t=145853
strokedmyford- Posts : 126
Re: oil filter adapter
most of these fprds with big headers you have to use a 90* adapter... no problems on mine so far I have been running it for 12 years....
the Coug- Posts : 3055
I was wondering if anyone experienced any oil psi drop. I just worry about changing something when everything has lived so well the last 5 years. Thanks
I came real close to using that adapter, but just cut the crossmember instead. Lem suggested it, and he wouldn't suggest something that would be a problem in any way.
schmitty- Posts : 4538
I would consider the one from L&L products before the factory ford one. When I swapped into my 86 F150 the ford one still didn't clear because it is too deep. L&L has a real short adapter and you have to run a remote oil filter mount. I guess really it depends on your situation.
jasonf- BBF CONTRIBUTOR
thanks
You gettin close to done and ready to run?
I have been using 90* adaptors for like I said 12+ years and Never had one single problem yet. I have one on my new engine and works great.....had one on my small block Boss car sense 75, so if it was going to give any troubles it should have by now.....
No problems here either.
Curt- Posts : 2791
schmitty wrote:You gettin close to done and ready to run?
Getting close hoping to make the first race in June.
If we can't stop these monsoon rains, I might be able to come run Central City too.
schmitty wrote:If we can't stop these monsoon rains, I might be able to come run Central City too.
Schmitty you are so beginning to sound like a farmer Bitch it it rains and Bitch if it don't.......
sorry someone made me do it.....
No complaints here, the rain is letting me get a bunch of stuff done on the ole mud truck.
Randy, did you use the factory ones or aft market?
i know with the factory ones if paid attention to (not that many ) they always seem to have a film of oil around them. They were all the ones with the factory oil cooler lines so they could have been the culprit. Or i guess leaks from above.
Diggindeeper- Posts : 800
I have used 3 different factory ones now I use to use the 90* adaptor it came on 6 cyl engines, then I used one that came on the Boss and SCJ engines which had an oil cooling setup for an external cooler and now I use the new style which I got from Lem ...
» FRPP oil filter adapter
» Oil filter adapter
» oil filter adapter?
» FORD 90 degree oil filter adapter
» Wanted: 90* oil filter adapter...
