FORD 90 degree oil filter adapter
+6
85lebaront2
powerstrokeace
10 posters
FORD 90 degree oil filter adapter Empty FORD 90 degree oil filter adapter
Post  powerstrokeace March 9th 2014, 2:30 am
has anybody found a source for the 2 o-rings for this adapter. I have called fords tech line and it seems i can never get through
Ace
powerstrokeace
powerstrokeace
FORD 90 degree oil filter adapter Empty Re: FORD 90 degree oil filter adapter
Post  85lebaront2 March 9th 2014, 7:54 am
I was actually able to get them from my local dealer when I changed from the basic adapter to the external oil cooler one.
85lebaront2
85lebaront2
Post  powerstrokeace March 9th 2014, 11:25 am
any part numbers?
Ace
powerstrokeace
powerstrokeace
Post  Curt March 9th 2014, 12:31 pm
Can you measure the O-rings?
Post  powerstrokeace March 9th 2014, 12:33 pm
There on the block right now
Ace
powerstrokeace
powerstrokeace
Post  Curt March 9th 2014, 12:34 pm
All you need is a thickness and either an ID or OD measurement.
Post  Curt March 9th 2014, 1:27 pm
The next time you have it apart reference this.
Click here for cross reference
Post  85lebaront2 March 9th 2014, 3:22 pm
powerstrokeace wrote:any part numbers?
Ace
Unfortunately not, my son-in-law picked them up for me and didn't give me the receipt. He just said, "don't worry about it".
85lebaront2
85lebaront2
Post  supervel45 March 9th 2014, 4:20 pm
Ace
I checked around alittle, and did not find any part numbers or replacements for this model online. I think Curts idea may be best.
Post  85lebaront2 March 9th 2014, 5:30 pm
Ace
The O-rings should be the same for the 1988-early 1990 and late 1990-1997 oil cooler adapters. The early adapter (up to 1986 for certain) used 1 O-ring to the block and a gasket under the bolt head.
85lebaront2
85lebaront2
Post  Lem Evans March 10th 2014, 8:57 pm
powerstrokeace wrote:has anybody found a source for the 2 o-rings for this adapter. I have called fords tech line and it seems i can never get through
Ace
Just go to a joint that has an o-ring assortment and find one that fits in the groove.
Post  69F100 March 10th 2014, 9:07 pm
I got a whole unit if I think about I get and see what size o ring but I think it carry the same oring as a oil filter for the block and the gasket under the bolt is the same as a oil plug in the oil pan I will look at the bolt and make sure they are not a o ring in the housing where it goes thro
Post  strokedmyford March 10th 2014, 10:32 pm
The big o-ring is the same as the small fuel filter cap on a 6.0 diesel. The small o-ring I think there is a size that works in most a/c o-ring asortments. Any tech. that works on 6.0 diesels should have a few lying around
strokedmyford
strokedmyford
Post  strokedmyford March 11th 2014, 3:53 pm
part # AS568-027 small O-ring
part # AS568A-145 big O-ring
Most places that sell O-rings should recognize  the part#
http://www.ebay.com/itm/O-Ring-EPDM-AS568A-145-3-32-0-103-Black-ID-2-9-16-2-550-OD-2-3-4-Meddi-/331142690668?pt=LH_DefaultDomain_0&hash=item4d19a4776c#ht_1923wt_1238
http://mykin.com/as568-027-nitrile-70.html
strokedmyford
strokedmyford
Post  powerstrokeace March 22nd 2014, 11:27 pm
Ace
Lem how much is the complete oil adapter kit now? i just may pick up a spare
Ace
powerstrokeace
powerstrokeace
Post  85lebaront2 March 23rd 2014, 7:01 am
Ace
Ace
I have the one I took off my 86 when I added the oil cooler (external, not the built in leak). This is the style that uses one big O-ring and a gasket under the bolt head.
85lebaront2
85lebaront2
Post  Lem Evans March 23rd 2014, 12:23 pm
Ace
Ace
$82.95
FORD 90 degree oil filter adapter Empty O rings
Post  White Lightning March 23rd 2014, 1:08 pm
Ace
X2...O-rings are O-rings...they're either round or square and one material or another. I went to NAPA and bought a box of a couple hundred assorted ones.....
Rob
White Lightning
White Lightning
Post  8liter May 26th 2014, 4:32 pm
I have two of these adapters, and I was noticing how the oil is routed if you take the plugs out. It appears that the oil by-passes the filter if you hook up a cooler to the adapter. Am I looking at this correctly? Could it bypass the filter completely?
8liter
8liter
Post  85lebaront2 May 26th 2014, 4:50 pm
I believe it goes, oil pump, out through adapter, cooler, back into adapter, through filter, from there into the block.
85lebaront2
85lebaront2
Post  8liter May 27th 2014, 4:44 pm
85lebaront2 wrote:I believe it goes, oil pump, out through adapter, cooler, back into adapter, through filter, from there into the block.
FORD 90 degree oil filter adapter IMAG0726_zps75ddf1c7
The way it looks is when it comes from the pump to the adapter, it can go to the filter or the cooler. When it comes out of the filter it can goto the motor or the cooler. How is it going to move oil thru the cooler in the configuration? How do most of you guys run an external oil cooler?
8liter
8liter
Post  85lebaront2 May 27th 2014, 5:01 pm
You must be missing a relief or bypass valve. Mine has a bypass valve that will bypass the cooler if it is blocked or too restricted. Even the infamous water to oil cooler has one. I am not going to try to take mine off for pictures unless I need it off for another reason.
85lebaront2
85lebaront2
Post  70FB May 27th 2014, 5:47 pm
I have one 90* deal and one for the line hookup for remote filter. I don't plan on using either if somebody needs it. Maybe il take a pic and post them up.
70FB
70FB
Post  85lebaront2 May 28th 2014, 10:11 pm
[img]https://s1367.photobucket.com/user/85lebaront2/media/Oilcooleradapter_zpse46f42e9.jpg.html?filters[user]=136341332&filters[recent]=1&sort=1&o=0[/img]Here is a picture of my adapter when I first got it from Pick-n-Pull in Virginia Beach.
85lebaront2
85lebaront2
Post  70FB May 30th 2014, 10:49 am
Here is the one I have. I tried to take the picture close enough to see the part number. It available if anyone needs it.
FORD 90 degree oil filter adapter DSC00838_zpsceada8a8
70FB
70FB
