FORD 90 degree oil filter adapter
+6
85lebaront2
powerstrokeace
10 posters
Page 2 of 2 Previous  1, 2
FORD 90 degree oil filter adapter - Page 2 Empty Re: FORD 90 degree oil filter adapter
Post  powerstrokeace May 30th 2014, 8:57 pm
70FB wrote:Here is the one I have. I tried to take the picture close enough to see the part number. It available if anyone needs it.
FORD 90 degree oil filter adapter - Page 2 DSC00838_zpsceada8a8
Is this new or used? I wish for would have a part number as a service kit to replace the o-rings. Mines like 15 years old. I would feel real safe replacing the o-rings. Also how much do you want for that. There should be 3 parts to that not counting The o-rings
Ace
powerstrokeace
powerstrokeace
Post  70FB May 31st 2014, 6:51 am
I wish I saw this last night. I'm back at work now and could match the orings up with a Cat part #. I'll double check how many parts it is when I get home. Or if somebody has the size and measurements on it I could get them today and send you some. I've got a mic with me.
70FB
70FB
Post  powerstrokeace May 31st 2014, 8:54 am
70FB wrote:I wish I saw this last night. I'm back at work now and could match the orings up with a Cat part #. I'll double check how many parts it is when I get home. Or if somebody has the size and measurements on it I could get them today and send you some. I've got a mic with me.
That would be awesome if you could do that.
Ace
powerstrokeace
powerstrokeace
Post  70FB May 31st 2014, 10:16 am
I have orings for the bolt but not the flat ones that are on each end like the filter size. Our largest is maybe 3/4 the size.
70FB
70FB
Post  70FB May 31st 2014, 1:20 pm
70FB wrote:I have orings for the bolt but not the flat ones that are on each end like the filter size. Our largest is maybe 3/4 the size.
Home now...Its an oring on the block side. I'll get the measurements on it for both orings before boxing it up. It got sold this morning.
Bolt oring is .075 thick.
and 1.350 inside diameter.
Oring on block side is .1 thick
and 2.625 inside diameter.
Keep in mind guys this is trying to measure a rubber oring.......
70FB
70FB
