Oil Filter Adapter
QtrWarrior
Page 1 of 2
Page 1 of 2 • 1, 2
Oil Filter Adapter
While supplies last.
Allows the use of larger oil filter ( Fram HP-6 or Wix 51222R) for less restriction. Adapter replaces oil filter fitting, and screws into the block. Plate with o-ring seals against oil filter boss, New filter seals against plate.
Adapter has 1 1/2 -12 thread on filter side.
$25 includes shipping.
[img][/img]
[img][/img]
QtrWarrior- Posts : 2703
Re: Oil Filter Adapter
Ok I understand the o-ring and the Adapter that replaces oil filter fitting, But whats the six sided one for ?
OH! and I'll take one. maybe, if it clears headers. What dia. and Lt. are the filters
res0rli9- BBF CONTRIBUTOR
The hex piece is used to install the adapter. The adapter has a hex on the inside.
I'll measure the filter when I go to the shop later..
bumpage
Did you get a chance to check the dia.& Lt. of the filters.
Doug Rahn wrote:Wix is 4.6" dia. and 6.21 tall, Fram is 4.625 dia. and 6.688 tall.
Thanks Grandpa !!
QtrWarrior wrote:Doug Rahn wrote:Wix is 4.6" dia. and 6.21 tall, Fram is 4.625 dia. and 6.688 tall.
Thanks Grandpa !!
No problem "Big Daddy"!
I also forgot to add they can use the Wix 573003R which has a littler higher Max flow rating (30GPM) as compared to the 51222R (28 GPM). Both have a by-pass valve setting of 18-22 psi. Same dia. and length.
Thanks Grandpa !!
X2 ya thanks
I'll go and see if it'll work, mite have to use an Adapter with an Adapter.
Mike
I'll take one...
I'll take one...
jbozzelle- Posts : 3705
jbozzelle wrote:Mike
I'll take one...
Works for me John !!!
I'll drop a check in the mail for you over the weekend.
What is the small thread size?
If it's 3/4-16 I'll take one. I sent you an email too - thanks in advance for the info.
Carter
Carter
wirtzcf- Posts : 7
wirtzcf wrote:If it's 3/4-16 I'll take one. I sent you an email too - thanks in advance for the info.
Carter
I'll check it today...It is what ever size the threaded hole in the block is..
QtrWarrior wrote:wirtzcf wrote:If it's 3/4-16 I'll take one. I sent you an email too - thanks in advance for the info.
Carter
Mikey, the thread in the block is 1-1/16" x 12.
The PH8A filter thread is 3/4-16, so you're telling me it's not the same on the block side?
wirtzcf- Posts : 7
wirtzcf wrote:The PH8A filter thread is 3/4-16, so you're telling me it's not the same on the block side?
Look at the picture of the parts posted on the previous page. The big side goes into the block, the small side goes into the filter.
Exactly, The block is bigger..
dfree383 wrote:wirtzcf wrote:The PH8A filter thread is 3/4-16, so you're telling me it's not the same on the block side?
Dave, Actually, The big part goes in the filter..small side in the block..
The HP6 thread size is 1 1/2-12. So the filter side should be the bigger end.
I have an HP6 setup with two cases of filters that I couldn't sell, so I'm just going to use it on my Dodge V10 truck. Unless it's different from all the other mopars, the block side fitting is 3/4-16, so this won't work. Since both Fords and Mopars use the same filters I was hoping the block side fitting would be the same. That's an awesome adapter - wish I could use it.
wirtzcf- Posts : 7
Correct me if I'm wrong Mikey but maybe this will clear up some of the confusion.
Thanks Douglas
Page 1 of 2 • 1, 2
» Oil filter adapter
» oil filter adapter
» oil filter adapter?
» Header adapters and oil filter adapter
» Ford Racing 90deg Filter Adapter
Page 1 of 2
