Oil filter adapter
Oil filter adapter
Who makes a good remote oil filter adapter, for BBF? I'm building a full size truck for a friend, having issues with the steering shaft, I need to move the filter.
chuck- Posts : 414
Re: Oil filter adapter
It's not really a remote deal, but the one from Ford Racing turns the filter 90 degrees and allows you to clock it any direction. Works great, no leaks.
maverick- BBF CONTRIBUTOR
CV products and Peterson are two good ones......filter mounts.
Here is a Canton deal that goes on the block....
https://www.cantonracingproducts.com/product/22-595/22-595----FORDMOPAR-90-DEGREE-ROTATING-REMOTE-FILTER-ADAPTER/
System One also makes some very nice ones.
http://www.system1filters.com/remotemounts.htm
Keith
Keith
/\ X2 what Lem said!
CV Products makes a really nice one available in different sizes to accommodate different filters machine work and finish are Class A and the ports have radiuses for improved flow. I personally use the one that accepts the big azz F350 diesel filter.
Peterson has a really cool one with a built in primer pump and has the same type drive spud you can use on their external oil pumps. It's also available in different sizes. All you need is a good cordless drill and you can pre-prime the engine before start up.
» oil filter adapter
» oil filter adapter?
» Oil filter adapter
» FORD 90 degree oil filter adapter
» Wanted: 90* oil filter adapter...
