Oil filter adapter
Oil filter adapter Empty Oil filter adapter
Post  Bart Knox April 10th 2016, 8:10 am
What will I need for a oil filter adapter for my 95 bronco? Can I get away with a factory adapter or will I need a remote filter adapter
cutting the crossmember is a bad idea (been down this bad road)
small block crossmembers is different then the 460/diesel crossmember so the factory adapter will not work
the adapter pictured above might work but I am thinking it will have clearence issues as well
somebody that has installed the above on a 460 going into a small block Fseries 80-96 crossmember would be able to confirm one way or the other
Found this on Google... Was a post on 460ford from fordinfo
Bart Knox
Oil filter adapter M-688013
Bart Knox
Bart Knox
http://W. B Knox&son LTD Huntsville Ontario
