Motor Plate Question ....
ultimatelenny
Barney
posford
Motor Plate Question .... Empty Motor Plate Question ....
Post  posford June 8th 2012, 8:25 am
At what horsepower level do you think motor plates are necessary. This would be in a Pro Stock pulling truck ( hoping for around 850 hp ). I currently have solid motor mounts but I'm concerned about the bolts pulling out or breaking the block.
posford
posford
Motor Plate Question .... Empty Re: Motor Plate Question ....
Post  whatbumper June 8th 2012, 9:33 am
posford wrote: ...but I'm concerned...
It's time now.
Post  Barney June 8th 2012, 10:22 am
I agree.
Barney
Barney
Post  ultimatelenny June 8th 2012, 10:27 am
X3
ultimatelenny
ultimatelenny
http://www.ultimateconverter.com
Post  richter69 June 8th 2012, 12:38 pm
X4
Post  69F100 June 8th 2012, 4:47 pm
x5
I agree if you start wondering if something is strong enough time to make the change and I think with 850hp it is time
Post  schmitty June 8th 2012, 9:27 pm
A motor plate is a great deal, because it is so easy to install and makes it much cleaner and easier to work on. Call Randy Malik and get the one he sells, you won't be disappointed.
Post  Wheelie58 June 8th 2012, 9:55 pm
I sent you a PM with information about the motor plates that I make for BBFs.
Recently, forum member IcallhimGeorge installed one of my plates for an O.E. cover in his truck and from all reports has a successful conversion from side mounts to motor plate, even retaining his power steering and alternator in the process.
Thanks,
Keith Fulp
www.KeithFulpMotorsports.com
678-458-2033
Wheelie58
Wheelie58
Post  posford June 8th 2012, 10:13 pm
O.K., Front and Midplate it is . On the mid-plate, I already have the Lakewood block saver plate and if I add a 3/16 mid-plate the trans. input shaft won't quite reach all the way thru the front clutch disc. ( runnin' a 2 disc clutch ). How do you guys install your mid-plates ? Pics would help too.
Keith, I'll be giving you a call next week. ( the PM didn't come thru ).
posford
posford
Post  Wheelie58 June 8th 2012, 10:52 pm
If it helps....my mid plates are .100 (or so) thick and 32" wide.
Custom plates are no big problem too.
Keith
678-458-2033
Wheelie58
Wheelie58
Post  Barney June 8th 2012, 11:18 pm
Keith's stuff is top notch. Solved all my problems except cholesterol.
Barney
Barney
Post  Wheelie58 June 9th 2012, 2:17 am
Barney wrote:Keith's stuff is top notch. Solved all my problems except cholesterol.
OK
Here is the deal...
Oatmeal for breakfast.
Turkey for lunch with mustard.
Grilled chicken or fish for dinner and walk 2 to 3 miles per day.
You can do this deal at the track.
If your cholesterol numbers decrease (and they will) you can buy a KFM t-shirt to sport your goods!
Free KFM mojo.
Just look what it did for Dan Hobbs!
All but the Superman decal!
Wheelie58
Wheelie58
