rotor phasing?
rotor phasing?
can someone explain rotor phazing to me? What is this done for?
cooter- Posts : 220
Re: rotor phasing?
It's putting the rotor button in proper alignment with the distributor cap, when the dist. is locked out, usually with a crank trigger. I have an old cap with a hole drilled right at the #1 terminal. Crank up the engine, shine the timing light through the hole and set the dist. where the rotor button just leads the terminal.
BigDave65- Posts : 567
Re: rotor phasing?
so this is to phase the dist to the crank trigger? Would you ever need to phase a rotor on a regular dist set up? Thanx for your explanation.
cooter- Posts : 220
Re: rotor phasing?
cooter wrote:so this is to phase the dist to the crank trigger? Would you ever need to phase a rotor on a regular dist set up? Thanx for your explanation.
YES ... but, that is a bit more difficult to do.
