rotor phasing?
chuck
rotor phasing? Empty rotor phasing?
Post  chuck April 4th 2010, 11:10 am
do you have have to cut a hole in the cap & use a timming light to get it correct with a crank trigger? Or can you line it up number one?
chuck
rotor phasing? Empty Re: rotor phasing?
Post  c.evans April 4th 2010, 11:58 am
Just line the rotor up with your number one terminal post. The beauty of the crank trigger is that you can turn the distributor housing however much you want in order to achieve the correct rotor phasing,,,,,and never affect the timing.
Hope this helps,
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  richter69 April 4th 2010, 12:08 pm
should be able to just line it up, but to make certain you'll need to cut the hole in the cap and use a light..........or just get another like a stock cap to put a hole in. Starter savers etc can change the time and just because the magnet is lined up does not mean its wnen the coil fires.
Post  Curt April 4th 2010, 12:26 pm
I have ran many laps with my phasing cap. Not a big deal on a drag car. However, I also have one that is not windowed. Arrow
Post  richter69 April 4th 2010, 1:03 pm
Curt wrote:I have ran many laps with my phasing cap. Not a big deal on a drag car. However, I also have one that is not windowed. Arrow
same here, the hole does not hurt, just dont stick you finger in it with it unning or it might................
Post  Curt April 4th 2010, 1:10 pm
richter69 wrote:same here, the hole does not hurt, just dont stick you finger in it with it running or it might................
Where have I heard that before? lol!
Post  chuck April 4th 2010, 1:17 pm
LOL!!! The only pain is we have the small cap. Not much room to see.
chuck
Post  bruno April 4th 2010, 1:27 pm
Sad ... and also make sure you use one of them cheap timing lights .... my digital snap-on and my dial mac one has had my base timing around 27-28* .... i did a back to back test this past week and when i used the snap-on and the mac one timing was bouncing everywhere but as soon as i used a craftsman no-dial deal it was rock solid ..... also the engine sounds a little diff when you have the freaking timing correct .... and msd makes one also chuck Wink
later guys
Nick
http://WWW.CKRME.COM
Post  BOSS 429 April 6th 2010, 12:34 am
thru testing a lot of diff lights over the years i have found sometimes the spark plug wire is TOO DAM good, try checking your timing again with a cheap wire with both lights, the killer snapon light seems to have a hard time picking up on a good wire,sounds silly i know, if it still doenst work as good light might be bad
Post  whatbumper April 6th 2010, 9:06 am
the most accurate timing light (and I've had a bunch) that I have had is my Craftsman and the one I got from Harbor Freight. Neither was a dial back and compared to a computer both were more accurate than my Snap-on, Matco, or Actron's.
The Snap-on read 9 degrees retarded from actual and we were running nitrous at the time.
Post  Larry Williams April 6th 2010, 4:17 pm
I use the MSD timing light and love it.
Larry Williams
Larry Williams
Post  whatbumper April 6th 2010, 4:24 pm
Larry Williams wrote:I use the MSD timing light and love it.
I hear MSD made theirs just for the above reasons. Buddy has one and it is pretty good.
Post  richter69 April 6th 2010, 6:48 pm
whatbumper wrote:the most accurate timing light (and I've had a bunch) that I have had is my Craftsman and the one I got from Harbor Freight. Neither was a dial back and compared to a computer both were more accurate than my Snap-on, Matco, or Actron's.
same light I got, 16v dont bother it either..................
Post  whatbumper April 6th 2010, 10:28 pm
I was scared to use it on 16v. I always run it to the 4 wheeler battery.
