dizzy phasing
dizzy phasing Empty dizzy phasing
Post  dirtbogger May 1st 2011, 9:52 pm
Please explain what this means and how to do it. Duraspark unit. Thanks
dirtbogger
dizzy phasing Empty Re: dizzy phasing
Post  c.evans May 1st 2011, 10:12 pm
When one of the tangs on the reluctor (or star wheel) is lined up with the magnetic pick-up, then you need to make sure that the rotor is lined up with one of your terminals in the distributor cap.
The amount of vacuum advance and the amount of centrifugal advance you have in your distributor enters into this equation also. I.E. if you have several degrees of centrifugal advance, then you want the rotor to be at the leading edge of the terminal in your cap, so that when you are at full advance you are centered on the terminal.
Hope this helps,
Charlie Evans
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  dirtbogger May 2nd 2011, 6:32 pm
Thanks, I assumed thats what it had to be, but my nephew and a buddy of his wanted to argue the point. I'll show him this!!
dirtbogger
Post  racnrick May 2nd 2011, 7:15 pm
Here is MSD's instructions,
http://www.msdignition.com/instructions/Products/frm29645_tech_bulletin_rotor_phasing.pdf?terms=phasing
racnrick
Post  c.evans May 2nd 2011, 8:32 pm
Remember our BB Ford distributor rotates counterclockwise.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  dirtbogger May 3rd 2011, 5:23 pm
c.evans wrote:Remember our BB Ford distributor rotates counterclockwise.
Charlie
Yes sir, all looks good, thanks
dirtbogger
