engine hwlp
all junk
engine hwlp
my buddy built a 30 over 429 with stock dove heads roller rockers solid lift 605/605 the car is using a stock 3/8 fuel line idles at 8 lbs. fuel pressure when the motor goes under a load presure drops to 3-4 pounds the fuel filter stays full of gas and fuel in the bowls does not drop i think fuel line is to small what do you guys think?
all junk- Posts : 61
Re: engine hwlp
How does it run, does it act like it's starving for fuel? Electric pump? My self, I'd prefer 1/2" minimum from tank to engine, but, if it's not running out of fuel, he's probably ok.
Nevs- BBF CONTRIBUTOR
Re: engine hwlp
3000 rpm it pops thru the mufflers bad car wont turn over 3500 rpm or so runs like shit stock mechanical fuel pump
Re: engine hwlp
That sounds like starvation to me. I doubt the mechanical pump is doing it's thing. Sounds like it's time for him to spend a little money
Re: engine hwlp
thanx we will try it keep you posted
Re: engine hwlp
I always make sure it will fill a gallon jug in 15 seconds or less. If not, you need more volume. just my opinion!!Nevs wrote:That sounds like starvation to me. I doubt the mechanical pump is doing it's thing. Sounds like it's time for him to spend a little money
dirtbogger- Posts : 172
Re: engine hwlp
Yep. I think so.
Had a stock fuel line on my boy's 350ci camaro. We put a blow thru turbo on it and until we upgraded the line the car felt like you hit a wall at 4500rpm. Shift and it'd pull again, the fall over again at about 4500.
4thHorseman- Posts : 400
Re: engine hwlp
dirtbogger wrote:I always make sure it will fill a gallon jug in 15 seconds or less. If not, you need more volume. just my opinion!!Nevs wrote:That sounds like starvation to me. I doubt the mechanical pump is doing it's thing. Sounds like it's time for him to spend a little money
That's an easy way to check. Good idea
Re: engine hwlp
1 gallon in 15 seconds? That's 4 gallons per minute. 240 gallons per hour.
There's no reason to need that much flow unless you're running 1000 HP.
Overkill in this case.
If the fuel pressure is still 3-4 lbs at WOT then your problem lies somewhere else. That pressure exists because the pump is pushing more fuel than the carb can use.
Greg
Greg
Greg_P- Posts : 1009
Re: engine hwlp
Greg, that amount of fuel is at a "no pressure" level. When a fuel pump starts having to "push" pressure that flow amount will go down considerably. At WOT my 600hp motor had a fuel consumption of 80 gal/hr on the dyno. I would think that the pump has an issue of some sort, either the line is too small, or the pump isn't capable of delivering the amount of fuel required.
schmitty- Posts : 4538
Re: engine hwlp
I hear what you're saying, BUT....
If the carb wanted more fuel than the pump could push, wouldn't the fuel pressure be zero?
Re: engine hwlp
Not necessarily, as there is a restrictioin at the needle and seat, and that is where the 3 or so psi is. More psi is needed to keep the fuel bowls full at WOT.
» 514ci BLUE THUNDER HEADED ENGINE & bbf parts,and engine for sale
» need info asap on engine combo ( 4.3 vs 4.5 crank) ordering it by tommmorrow details inside of engine plans
» C9VE engine from 69 Continental -- Have questions about where to go with this engine
» ENGINE RPM DROPS & ENGINE DIES AT IDLE & BRAKE PROBLEMS
