C4 No forward gears
+6
342g
61coon
whitefield
Gregaust
Tommyj466
10 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: C4 No forward gears
Tommyj466 wrote:Well, I pulled the tranny Friday night. Found one sealing ring on the stator support dislodged, but nothing else. Clutches and seals in forward clutch were OK. Upgraded planet to PA 6 pinion while I had it apart. Fired it up while ago and all appears to be good. Thanks for the replies!
TJ
Glad you found the problem !
whitefield- Posts : 2244
richter69 wrote:that will do it, if it wasba teflon ring you have to make sure the scarf cuts are put together right.
Some vaseline or transmission assembly lube works great to keep the cut ends in the groove. Personally I always used the cast rings on C-4's. I know some say the teflon is better, but never had a problem either... of course never found a problem with the three gear front planet with the torrington bearings either. Seems one can spend a lot money on parts upgrades.
466cj- Posts : 391
Page 2 of 2 • 1, 2
» C6 lost forward gears
» C-4 no forward gears 1-2-3. but has a jerky reverse
» Does adding a wave plate help the forward drum last after trans brake installation
» Forward clutch plates
» 5 disk forward drum
Page 2 of 2
