2X4 Carb Setup
+13
kim
466cj
Mustang-junky
dirt_worker
jmf32
17 posters
2X4 Carb Setup - Page 2 Empty Re: 2X4 Carb Setup
Post  IDT-572 August 2nd 2012, 3:12 pm
I did read where you closed the throttle blades on both carbs, I only saw where you said it was the same as it was run as a single. If you haven't, close the throttle blades on both carbs and start over.
When the were run single the blade opening will have been twice as much as it will need with duals.
You may have already done this is so sorry.
Set your timing with a light and then concentrate on the carbs and intake.
Post  jmf32 August 2nd 2012, 4:24 pm
Thank you,
I will set timing at 34-36 and check for a vacuum leak when i get home from work with some spray or blow torch method to see if the motor revs high. i may block some of the air from the fan(s) blowing at the carbs also. it gets a good wind cycle going from the fan to the carbs. i'll let you know what i find
jmf32
Post  Mustang-junky August 2nd 2012, 7:11 pm
My guess is that the gaskets moved when you "slid the manifold forward" during the install to avoid having to remove the distributor. Sounds like a vacuum leak to me.
Jess
Mustang-junky
Mustang-junky
Post  maverick August 2nd 2012, 7:25 pm
That thing is pulling air from SOMEWHERE. I'm guessin' the water/meth system is the culprit.
Post  jmf32 August 3rd 2012, 6:52 am
Thank You,
i did manage to find a vacuum leak right above #6 cylinder with a small shot of brake cleaner. only there though.but it is there for sure,very noticeable i did use my old metal/rubber gasket on this install. i did put permatex around the ports but it did not seal so a new gasket is next to do. i also want to add the 5/8" waterpump bypass fitting on the front of the intake. this intake does not have one. i have the bypass hose hooked to the thermostat housing right now. i have the meth unhooked and the ports plugged. i did manage to get a slightly lower idle,only very slightly less idle by turning the idle mixture screws all the way in. i can get the engine to idle by retarding the distributor but i can't advance the timing without the engine revving 2500 plus maybe 3000rpm or more with the throttle plates closed. in other words, timing is way retarded. idle mixture screws are turned all the way in.throttle plates are closed and idle stop screw is not touching anything and the motor is revving super high and starts running away when i advance the distributor to say a reasonable 10-15 degrees BTC. i am probably at 30 degrees BTC to get it to idle and it is looking like i need to seal the intake manifold first.
any other suggestions? Thank You in advance.
i will post back after i change the intake gasket
jmf32
Post  jmf32 August 4th 2012, 1:29 am
Hi to all,
I wanted to let you know where I am at in this procomp 2x4 with edelbrock 600s.
The car is running fair for having some issues as of now. I do have a vacuum leak at #6 cylinder. it is not a noticeable leak by ear but it is there when sprayed with brake cleaner. I plan on changing the intake gasket ASAP.
Basically my carbs are not metering the fuel low enough at idle, so my idle (due to fuel and air) is too high in rpms to set my timing where i would like. when i try to advance the dist to a normal setting, the engine revs very high in rpms. to give you an idea of how it sounds, it sounds like a drag car at half throttle but my throttle plates are closed.now i am wondering why it is doing this. i did drive the car down the road and the engine responds well with the 2x4s. At WOT, the engine comes on strong but my overall advance is purposely set retarded for now to get an idle that is low enough for the street.that may be due to the vacuum leak. i am hoping that after the gasket change, sealing the vacuum leak will let me actually use the actual idle stop screw on the side of the carbs. thanks
jmf32
Post  jmf32 August 4th 2012, 2:09 am
Here are some pictures of the 2X4:
http://www.dropshots.com/zoom.html?large=http://media9.dropshots.com/photos/1030798/20120801/b_224355.jpg
http://www.dropshots.com/zoom.html?large=http://media11.dropshots.com/photos/1030798/20120801/b_224459.jpg
jmf32
Post  res0rli9 August 4th 2012, 6:47 am
Link No Workie
Post  jasonf August 4th 2012, 10:36 am
Strange.I can get the links to open in a different page but I can't get them to post....
edit: figured it out. what a weird picture site.
2X4 Carb Setup - Page 2 B_224355
2X4 Carb Setup - Page 2 B_224459
Post  DFI429 August 4th 2012, 10:55 am
kim wrote:On the edelbrock carbs, the fuel mixture screw is an air bleed, the fuel flow is preset. So turning the screw in, makes it richer. To reduce the fuel your going to have to change the jet and the mixture rods.
Pretty sure the OP knows this already, but the above is COMPLETELY wrong. Edelbrock/Carter AFB carbs do not have idle air mixture screws... they are fuel-regulating. And changing the rods & jets will only affect the mixture when the throttle blades open. These aren't motorcycle carbs Rolling Eyes
http://www.edelbrock.com/automotive_new/misc/tech_center/install/1000/1405_manual.pdf
EDIT: The setup looks good, BTW Cool
DFI429
DFI429
Post  rmcomprandy August 4th 2012, 12:39 pm
jmf32 wrote:hi all,
i have got the procomp 2x4 intake running today. the edelbrock carbs were each tuned in on my old torker intake over the weekend. they were dialed in so i put them on the procomp and hooked them up. my timing was already set at aprox 36 degrees. i didn't have to move the distributor. i slid the intake on from the back to the front. it bolted up fine and i started it and noticed an immediate high idle with the procomp so i backed the idle screws out and it still idled fast. sorry no rpm gauge but it was fast. in fact the idle circuits do nothing right now and the idle screws are all the way out so i retarded the timing a little to get an aproximate 1000 rpms and the car idles fine now but i need to see where the timing is at now. i am in the process of tuning the set up now but it is overall running fine. i need to see where the timing is at before i continue tuning it. so far so good. i do have the carbs to open same time. i will post back as i tune with it. note: when i retarded the timing, the manifolds now glow orange at idle but as i advance the distributor it goes away but idles too fast. it is a non vac dist but i do have a msd adjustable timing dial on the dash to control some of the timing.
IF the carbs are completely closed and it still idles to fast ... idle airflow is entering the engine from SOMEWHERE.
Find the vacuum leak source before going any further;
Carb base gaskets not sealing everywhere, an open hole(s) not noticed, leakage around the manifold ports ... SOMEWHERE. Even right through a porous casting.
Post  jmf32 August 4th 2012, 8:57 pm
I really appreciate the replies concerning my problem.
I am waiting on a 3/8 NPT tap for the waterpump bypass hose. then i will change the intake gasket and try it.
the primary circuit on the carbs uses vacuum plungers that pull the metering rods into the jets. i did put longer metering rods in with the lightest(3" vacuum) blue springs hoping vacuum would close the jet somewhat. it didn't help it from revving. the carbs worked perfect ran as single on the torker. i mean perfect as far as adjusting then each one was put on the 2x4. it has to be the leak that i previously found at #6 cylinder and maybe another.
thanks for putting up the pics. i started thinking that it couldn't be done.
thank you
jmf32
Post  466cj August 4th 2012, 11:19 pm
The metering rods have no affect at idle. I'd suggest you put them back to what worked before. Best thing for you to do is stop messing with the engine and fix the vacuum leak. The last thing you want is to damage your engine - get the hint???
When you take the intake off check the port flange with a straight edge. I would not be surprised if it is not flat. Also lay the intake on the heads without the gaskets and make sure the angle is the same on the intake and head meaning no gap at the top or bottom. If either condition exists you will need to get the intake corrected. Yes we all know a new intake should not have these type of problems, but Pro-Comp is known for poor machine work.
466cj
Post  jmf32 August 5th 2012, 2:38 am
I changed the intake gasket and found a hole on the intake in the cast between #6 and #7 runners. about a 1/4" long.
it looked like where it had been cast. it was large enough to see light through to the inside. i sealed the hole with silicone for now but i will probably drill it and plug it. i did put silicone on the inside of the intake also where the hole is. if you have any suggestions to fix the hole, let me know.
i did put the original known good metering rods and springs back in also.
when i started it, the engine idled down to normal so it should be good to go as far as the carbs go.
i will post back tommorow with pictures of the hole and location as it may be a problem spot on many of these intakes.
also the hole on the outside was about a 1/2" different from the hole on the inside but it is the same hole. i was able to spray brake cleaner through it with the red straw thing on the brake cleaner can.
jmf32
Post  69F100 August 5th 2012, 2:57 am
if it was me i would be sending it back and having them send me a new one
Post  jmf32 August 5th 2012, 3:11 am
here are pictures of the hole:
http://www.dropshots.com/zoom.html?large=http://media11.dropshots.com/photos/1030798/20120804/b_225341.jpg
http://www.dropshots.com/zoom.html?large=http://media11.dropshots.com/photos/1030798/20120804/b_225245.jpg
here are the holes that i drilled and tapped for the waterpump bypass hose and heater hose
http://www.dropshots.com/zoom.html?large=http://media10.dropshots.com/photos/1030798/20120804/b_224518.jpg
here is a plug that i made on the back. i have no idea what this hole is for. i had to make a plug for it by cutting a slot in a huge coarse thread bolt. way more course thread than a NPT pipe thread plug. Does anyone know what this hole is used for?
http://www.dropshots.com/zoom.html?large=http://media11.dropshots.com/photos/1030798/20120804/b_224501.jpg
BTW only the large center plug needs plugged. the two smaller bolts do not need to be in there. the smaller bolt holes are not common with the inside plenum
jmf32
Post  jmf32 August 5th 2012, 3:16 am
here is my temporary fix. silicone inside and on the outside. do you think the silicone will be ok being where it is at? it should be as strong as a vacuum advance hose if you know what i mean. any suggestions?
http://www.dropshots.com/zoom.html?large=http://media11.dropshots.com/photos/1030798/20120804/b_230012.jpg
jmf32
Post  jmf32 August 5th 2012, 4:16 am
i also wanted to point out that i think that i had a gasket leak at the top of the #6 runner. i am not sure but on the inside of the intake, there was a dark stain that looked like air was being sucked in at the top. maybe it was my brake cleaner when i tested it. i should have took a picture of it.sorry
jmf32
Post  69F100 August 5th 2012, 6:49 am
If you going to keep it I would have someone weld it up or JB weld it the RTV will not stay your gas will eat it up and you will have a leak again.Well forget having it welded up aluminum has to be super clean before you can weld it and make it look good with the rtv in the crack it want weld up right.
Post  dfree383 August 5th 2012, 10:03 am
Get the Blue Thunder intake and be done with it.
Post  rmcomprandy August 5th 2012, 10:48 am
jmf32 wrote:here is my temporary fix. silicone inside and on the outside. do you think the silicone will be ok being where it is at? it should be as strong as a vacuum advance hose if you know what i mean. any suggestions?
Silicone was a bad idea.
Gasoline vapor will turn it to jelly and now the aluminum manifold surface is impregnated so, epoxy probably won't adhere without a lot of preparation.
That rear hole looked to be a flanged hole with hold-down bolts above and below the hole.
Post  466cj August 5th 2012, 1:39 pm
That is a casting defect. If you cannot get a replacement I'd grind out the silicone plus some to make sure it is all gone and have it welded.
466cj
Post  jmf32 August 5th 2012, 4:10 pm
Thank You for the replies.
I will clean it up there at the hole with a die grinder and weld a small bead across the hole. as far as the idle is concerned. the idle circuit i am guessing is still letting unwanted fuel to the engine. i would still like to lower the idle. right now it is probably 1500-1800 . i would turn it down but i can't. i do see an idle jet on the edelbrock diagram that was posted in this thread. i am going to the edelbrock link next to see if i can do anything with the idle jet. i drove the car just now and it is running as strong as i expected it too.just super fast idle. that may be normal for 2 carbs. any input?
jmf32
Post  richter69 August 5th 2012, 7:06 pm
pro comp strikes again.........
use jb quickweld on it.
Post  466cj August 5th 2012, 7:34 pm
jmf32 wrote:Thank You for the replies.
The edelbrock carb is basically the old Carter carb. and has been around since the 1950's. I'd seriously keep looking for a vacuum leak. If not make sure the throttle plates are closed down all the way on the secondaries and adjust the idle speed on the primaries. If you put the throttle plate up to a light should be no light shining through. If there is then the plates may no be properly seated in the bores.
As for the idle mixture screws turn them all the way in (clockwise) and back them off 1/4 turn and adjust from there. I'd also make sure your timing is set correctly. If the idle screws do not respond you still have a vacuum leak. Personally I think you still have a leak someplace.
466cj
