Push Rod length with Hyd. Roller
We are putting together a 545ci with a Hyd. Roller cam from Lem. I am using the FRPP SCJ heads. Can you use the standard pushrods for these heads( 2 Different lengths) or are they a special because its a Hyd. Roller?
Thanks Tore
Thanks Tore
Tore- Posts : 865
Re: Push Rod length with Hyd. Roller
Tore wrote:We are putting together a 545ci with a Hyd. Roller cam from Lem. I am using the FRPP SCJ heads. Can you use the standard pushrods for these heads( 2 Different lengths) or are they a special because its a Hyd. Roller?
Thanks Tore
The pushrods needed will be about .600" shorter than what would be used for a flat tappet hydraulic lifter.
Tore,
Expect your pushrod angularity to go to hell with the hydraulic roller set-up.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
I don't think I follow you ???? Possible problems with clearance in the cyclinder heads for the holes for the push rods to go thru??
Tore
Tore
Tore- Posts : 865
Is the hyd. roller for the 64 galaxie street car Tore?
No Rick its for the Torino, I thought I better put it back together to drive.
Tore
Tore
Tore- Posts : 865
