Push rod length checker.
Ok I am putting in a Summit cam and lifter kit k3500. D3 heads with bolt down pedestal rockers.
I am going to check my push rod length to be sure everything will be right.
Who makes a good push rod length checker? I don't want a high buck one tho. I do not do much engine building so this will be one of those tools that only get used only one time in a blue moon.
OldRedFord- Posts : 465
Re: Push rod length checker.
You can make your own Tim. Take a tubing cutter and cut a pushrod where ever you want to. I cut mine 2" from the end. Go to the hardware store and buy a threaded stud about 1.5" or 2" that will fit inside the P Rod after you Tap threads in it. I make them all the time.
Then measure the whole thing with a caliper?
Yes, You can adjust it to the length you need ,then measure it w/slide caliped.
bbf-falcon wrote:You can make your own Tim. Take a tubing cutter and cut a pushrod where ever you want to. I cut mine 2" from the end. Go to the hardware store and buy a threaded stud about 1.5" or 2" that will fit inside the P Rod after you Tap threads in it. I make them all the time.
Well, that's is a cool idea for sure!! Thanks!!
Bill
billandlori- Posts : 2081
Just be sure not to roll the engine over with a tough valve spring installed as that homemade adjustable pushrod will most likely bend.
» P-51 push rod length- help really dumb question
» Push Rod Length ?
» push rod length
» Push Rod Length?
» Push Rod length with Hyd. Roller
» Push Rod Length ?
» push rod length
» Push Rod Length?
