Fuel pump fluctuation
Tore
I have a HOlley Black pump and sometimes it runs right at 7 pounds regulated. Then sometimes it goes to 3 pounds and creeps up to 7 very slowly. Is this a sign the pump is taking a dump? The fuel pump is on a relay circuit so it gets non fluctuating voltage.
Tore
Tore
Tore- Posts : 865
Re: Fuel pump fluctuation
are you checking pressure before or after the regulator?
Tore wrote:I have a HOlley Black pump and sometimes it runs right at 7 pounds regulated. Then sometimes it goes to 3 pounds and creeps up to 7 very slowly. Is this a sign the pump is taking a dump? The fuel pump is on a relay circuit so it gets non fluctuating voltage.
Tore
Tore I was having the same problem with mine take the inlet filter out it is behind the inlet fitting mine was stoped up I just removed it ( it want be worth using when you get it out or mine wasn't) as I have a filter before the pump now. also take the i beleave it a brass srew with the spring behind it check and make sure everything is clean in there.
richter69 wrote:are you checking pressure before or after the regulator?
After the regulator.
Tore- Posts : 865
69F100 wrote:Tore wrote:I have a HOlley Black pump and sometimes it runs right at 7 pounds regulated. Then sometimes it goes to 3 pounds and creeps up to 7 very slowly. Is this a sign the pump is taking a dump? The fuel pump is on a relay circuit so it gets non fluctuating voltage.
Tore
I will take a look at that.
Thanks Tore
Tore- Posts : 865
i assume this is w it running also?
Erratic Fuel Pressure
Race Pumps do not work well with bypass style regulators. The fuel pressure will be erratic.
If the engine has erratic fuel pressure for a few minutes after re-starting and clears up the problem is likely from loosing prime.
Fluctuating fuel pressure at idle (unless you have a bypass style regulator) is usually due to a vacuum leak in the inlet line. Test this by replacing the inlet line with a short line to a 5 gallon fuel container….if it clears up, you have a vacuum leak.
. MagnaFuel considers excessive fluctuation to be over 1-1/2 pounds of pressure. Vibration, aeration, faulty gauges, or sharp changes in supply/pump pressure usually cause this. You should isolate the regulator with rubber mounting to tame vibration.
Mine fluctuates from 7to 8 lbs and the needle on the gauge is moving rapidly. I have a mallory pump and regulator with a returnable fuel system. Filter before the pump and fuel PSI gauge comming of the port on the psi regulator . It just started last season doing this.
P. S. Sorry didn't mean to jack your thread O.P.
whitefield- Posts : 2244
Also check out the regulator real good. I just changed the diaphragm and spring in my bypass regulator and it's back to rock steady.
richter69 wrote: i assume this is w it running also?
Yes it is.
Tore- Posts : 865
NP you streaker
That is interesting. The blue pump in my tbucket does the same thing. Sometimes it is 6 1/2 psi then sometimes it will be down to 3 psi. That is at the carb after the regulator. I never notice any difference in performance though..
jasonf- BBF CONTRIBUTOR
» Do I need to remove my already intalled fuel pump eccentric if I'm now going to be using an electric fuel pump?
» BG 400 fuel pump
» what fuel pump to run
» Magna Fuel Prostar seal
» Need some opinions/ Long
» BG 400 fuel pump
