line size
line size
On a regular cheater solenoid what size line is the fuel line typically? -3 or -4?
jasonf- BBF CONTRIBUTOR
Re: line size
between the noid and plate -3
Re: line size
That's what I would have guessed but wasn't sure. I need to get a couple fittings and I am not at home to go look for myself.
thanks a bunch,
thanks a bunch,
Re: line size
How much N20 and fuel can flow through a -3 line? Seems kinda small. Will it flow enough to support a 150HP plate?
4604X4- Posts : 108
Re: line size
prolly double that
Re: line size
Most kits have a hose with a -4 on one end and a -3 on the jet end. We make and sell these as well but we hose a -4 hose and have a -3 fitting for the jet end.. SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Re: line size
Well I am going to make sure I have both -3 and -4 fittings so I can go either way. Thankfully the little stuff is cheap.
» fuel line size
» Transmission cooler line size
» what fuel systems do you guys run?? and what size line?
» MSD 6AL, line lock, tranny dipsitck, carb fuel line
» What is the weak line in the drive line ?
