test n tune
test n tune
well made it to the track sat. with a club im in 65 cars showed im running a 1952 f1 truck. off the trailer it went 11.53 @ 112 second pass 11.58 @ 115 then the best after that was 11.71 worst 11.76 made 6 passes on motor. then try to spray and cars were breaking like crazy so only could run the 1/8 7.11 @101 7.14 @101 7.17 @100 125hp hit 50hp 7.22 @ 99 . then i was able to make 3 1/4 passed 11.13 @ 123.92 11.17 @ 123.83 125hp 50hp 11.22 @122 11.49 @ 117 and laid over the bottle was out. did have a great time truck ran with no trouble but didnt get in the 10s like i wanted but it is what it is beat up some chevys
quick 52- Posts : 612
test n tune
"quick 52" , Nice Passes !! ,what were the tunes?, sounds like you were having fun beatin up on some chevys,thatsa good thang always.Good runnin truck "quick52 ",Thanks MavManquick 52 wrote:well made it to the track sat. with a club im in 65 cars showed im running a 1952 f1 truck. off the trailer it went 11.53 @ 112 second pass 11.58 @ 115 then the best after that was 11.71 worst 11.76 made 6 passes on motor. then try to spray and cars were breaking like crazy so only could run the 1/8 7.11 @101 7.14 @101 7.17 @100 125hp hit 50hp 7.22 @ 99 . then i was able to make 3 1/4 passed 11.13 @ 123.92 11.17 @ 123.83 125hp 50hp 11.22 @122 11.49 @ 117 and laid over the bottle was out. did have a great time truck ran with no trouble but didnt get in the 10s like i wanted but it is what it is beat up some chevys
1970 ford maverick- Posts : 180
Re: test n tune
Those are some impressive runs! I'm sure you will get it down in the 10's soon enough.
Re: test n tune
i run a monty smith tune that was given to me at drag week 65n 52f 5.5pf and 27* total timing the is 42n 36f 5.5pf 30* total timing with a AR 3934 plug race gas on the 125hp hit and pump 93 on the 50hp i take extra timing out bc of kb pistons1970 ford maverick wrote:"quick 52" , Nice Passes !! ,what were the tunes?, sounds like you were having fun beatin up on some chevys,thatsa good thang always.Good runnin truck "quick52 ",Thanks MavManquick 52 wrote:well made it to the track sat. with a club im in 65 cars showed im running a 1952 f1 truck. off the trailer it went 11.53 @ 112 second pass 11.58 @ 115 then the best after that was 11.71 worst 11.76 made 6 passes on motor. then try to spray and cars were breaking like crazy so only could run the 1/8 7.11 @101 7.14 @101 7.17 @100 125hp hit 50hp 7.22 @ 99 . then i was able to make 3 1/4 passed 11.13 @ 123.92 11.17 @ 123.83 125hp 50hp 11.22 @122 11.49 @ 117 and laid over the bottle was out. did have a great time truck ran with no trouble but didnt get in the 10s like i wanted but it is what it is beat up some chevys
test n tune
Thank You "quick52", have a 289 in a 88 coupe, has a wilsons proflow plate that I will try both tunes real soon.Thanks again! MavMan
» Back from the dead...
» test n tune
» Is this adequate gain with the SCJs
» Test & Tune @ SRD
» Went to test & tune yesterday
» test n tune
» Test & Tune @ SRD
