Engine Sealer
CP598
Tore
Engine Sealer Empty Engine Sealer
Post  Tore October 2nd 2012, 6:46 pm
My son-in-law is having A problem with some porosity in the cylinder head. He had to opne the holes for the pushrods and hes got a small leak and we can see some steam coming out the Rocker Cover vent.
He put some Barr's Copper stop leak and that didn't do nothing.
Is there something better he can try?
Also somebody said try some Water Glass Sealer . I read on the net its used for concrete sealing. ANybody have any experience with this???
Thanks Tore
Tore
Tore
Engine Sealer Empty Re: Engine Sealer
Post  CP598 October 2nd 2012, 7:21 pm
Tore wrote:My son-in-law is having A problem with some porosity in the cylinder head. He had to opne the holes for the pushrods and hes got a small leak and we can see some steam coming out the Rocker Cover vent.
Thanks Tore
I used sodium silicate "water glass" to seal porosity in my A460 block cylinder wall. It appears to have done the job. Depending on how large the hole is, this may also be a solution for you. You can buy it at your local pharmacy. There are some epoxies available if water glass will not work for your application. Devcon makes several. Here's a link to sodium silicate.
http://www.sciencecompany.com/-P6375C670.aspx?utm_source=google&utm_medium=shop&utm_campaign=prod
Vern
CP598
CP598
Post  Tore October 2nd 2012, 7:29 pm
How much did you use to seal the block?
Tore
Tore
Tore
Post  Lem Evans October 2nd 2012, 7:31 pm
K & W stop leak.
Post  CP598 October 2nd 2012, 7:46 pm
Tore wrote:How much did you use to seal the block?
Tore
I bought a quart, poured almost all of it in the block. This was a bare block. I believe we sealed it up with torque plates and made block-offs for the water pump holes and then pressurized it. We then rotated the block on the engine stand several times. Sorry can't really remember all the details, it was a few years and brain cells ago. Very Happy I would take Lem's advice.
CP598
CP598
Post  TravisRice October 2nd 2012, 8:14 pm
Ceramic Seal should also work. Check your local dirt track supplier, they run it in most of the all aluminum deals that are hard to keep sealed up.
Post  richter69 October 2nd 2012, 8:17 pm
^^^^^ hit the newbie thread..... Wink
Post  TravisRice October 2nd 2012, 8:27 pm
10-4
Post  Frank Merkl October 2nd 2012, 9:24 pm
your probably better to pull the head off and put a tubing sleeve in it
Post  cool40 October 2nd 2012, 10:32 pm
TravisRice wrote:Ceramic Seal should also work. Check your local dirt track supplier, they run it in most of the all aluminum deals that are hard to keep sealed up.
this^^^
Frank Merkl wrote:your probably better to pull the head off and put a tubing sleeve in it
then this^^^^ Smile
Post  Tore October 3rd 2012, 9:36 am
Thanks for everybody's input. Hope the kid gets the sealer today and will give it a shot tonight.
Tore
Tore
Tore
Post  bbf-falcon October 3rd 2012, 10:51 am
Water glass has saved a many cyl. walls,blocks,and heads. Some good stuff,just make sure its clean of Antifreeze.
