dry sump/ vac pump
dry sump/ vac pump
OK guys ive never ran a dry sump or a vac pump but I'm wanting to put both on the new motor what should I put on it? I've been doing a lot of research and I'm starting to get confused...lol how many stages do I need on pump? Do I put 3 vane or 4 vane vac pump? Thanks guys..
fatal addiction- Posts : 433
Re: dry sump/ vac pump
Get with someone like Phillip Oakley, Lem Evans, (+ A number of others on the Site) and get a complete system thru them. They know what works and will get you everything right the first time.
fatal addiction wrote:OK guys ive never ran a dry sump or a vac pump but I'm wanting to put both on the new motor what should I put on it? I've been doing a lot of research and I'm starting to get confused...lol how many stages do I need on pump? Do I put 3 vane or 4 vane vac pump? Thanks guys..
call me Ill be glad run thru it with you
some dont need a vac pump, I have a few different engines that pull 15 plus without one
johnson,peterson,moroso,all make good pump,we use all 3, and have dynoed with all of them. I like peterson myself, their tank is one of the best because it doesnt foam the oil like some do
BOSS 429- Posts : 2371
dfree383 wrote:Get with someone like Phillip Oakley, Lem Evans, (+ A number of others on the Site) and get a complete system thru them. They know what works and will get you everything right the first time.
x2 on Phillip and Lem great pricing and great service after the sale
What is your ring package like? Engine size?
It has total seal rings. 632 w/ Thor heads 16.5 to1 comp.
fatal addiction wrote:It has total seal rings. 632 w/ Thor heads 16.5 to1 comp.
Axial height and radial width?
I'll have to look at the paper work I'll get back with u on that.
» Oil Pump Pick Up for Front Sump Pan and Kaase Pump
» WTB Dry Sump Pan and Vac pump
» dry sump and vac pump
» Oil pan , pump, sump
