Oil pan , pump, sump
If you where mud racing, bogging... What pan, pump, sump would u run... wide open usually 10 sec....??
thanks
please give part number , brand.... thanks...
thanks
bigunitmudracing- Posts : 159
Re: Oil pan , pump, sump
Moroso. Milodon and Canton all make some nice Big Pans that will fit. Look at their Truck pans and Flat Botton Drag Pans.
I ran a dump truck pan(12 qt) in my truck BUT I had flow baffles installed to keep the oil at the pump pickup, and ran a full louvered windage tray from canton.
lghting94- Posts : 762
any other imput????
10 seconds WOT at what rpm?bigunitmudracing wrote:If you where mud racing, bogging... What pan, pump, sump would u run... wide open usually 10 sec....??
thanks
6500rpm stock stroke good parts
If you are looking for an off-the-rack oil pan.......the Moroso 20614 does a good job.
will that clear in my 84 ford f250?
I did some looking online and for my truck they said moroso 24504 Is that pan good???
i've always raced with stock pans and never had a problem... but i dont want to find a problem either
bigunitmudracing wrote:will that clear in my 84 ford f250?
Measer the stock stuff you have been using and get on Moroso's website they have dimensions listed.
» Oil Pump Pick Up for Front Sump Pan and Kaase Pump
» Oil fill in a vac pump/wet sump set up
» dry sump and vac pump
» dry sump/ vac pump
