Oil fill in a vac pump/wet sump set up
PanaVet
I am going to have a vac. pump on my new wet sump build and I am wondering what others do to handle oil fills. Is there a valve cover cap that is sealed yet removable to pour oil in? Or, is there another way to handle this task?
Sorry if this seems like a dumb question. It was easy with my dry sump system lol.
Alan
Alan
Re: Oil fill in a vac pump/wet sump set up
GZ Motorsports makes some nice stuff...I use this....
http://www.gzmotorsports.com/VCV102A-Vacuum-Control-Valve.html
PanaVet- Posts : 47
We just pull a valve cover.
whatbumper- Posts : 3024
Peterson, summit, jegs all sell O ring weld on filler bungs with caps in both aluminum and steel. Moroso 85283, all-star 36160
460pulling- Posts : 249
Lem had mine made with the fill cap in each side and the vac hookup in the front.
If your valve covers have a hole with a rubber grommet, simply use that hole for adding oil.
Dave.
Dave.
LivermoreDave- Posts : 972
Naturally I thought of that, but also thought that setup might be a place for a vacuum leak as those twist lock caps are not always the tightest fitting.LivermoreDave wrote:If your valve covers have a hole with a rubber grommet, simply use that hole for adding oil.
Dave.
You make a valid point although if hot oil doesn't leak (fume) from the filler cap it may work. You could install an o-ring on the cap along with the gasket that usually accompanies the "twist-lock" type of filler cap. Also, before going to the extra expense, first install the valve cover with the "twist-lock", while the engine is running remove the "twist-lock" cap and simply hold your hand over the oil fill hole and watch the vacuum gauge.
Dave.
Dave.
» Oil Pump Pick Up for Front Sump Pan and Kaase Pump
» dry sump and vac pump
» dry sump/ vac pump
» Oil pan , pump, sump
