thinking winter
thinking winter Empty thinking winter
Post  quick 52 October 9th 2012, 2:08 pm
well its getting close to the season end an d thinking about the winter project. think im going to replace the v springs ago with ti retainer or is that overboard with a street strip car that goes to the track a few times a year.
quick 52
thinking winter Empty Re: thinking winter
Post  bigblok2000ranger October 9th 2012, 8:46 pm
Overboard probably a little but less weight in the valvetrain is always a good thing right.
Due to a trans failure my winter projects got an early start, I am installing a vacuum pump getting the intake ported that we didn't get done last year due to time constraints and buying a pair of Pro-Systems Dominators. Also gonna work on the weight.
bigblok2000ranger
bigblok2000ranger
Post  quick 52 October 9th 2012, 8:58 pm
bigblok2000ranger wrote:Overboard probably a little but less weight in the valvetrain is always a good thing right.
are you going with a belt driven vacuum or a elec. one see alot of elec. one at the track. watch your build this year and you really put out alot work on the truck hope it terns out for you
quick 52
Post  bigblok2000ranger October 10th 2012, 3:21 pm
Belt driven unit, the Morose 3 vane looks like it will get the nod. I think next year I should finally see what this thing is capable of. I got alot of problems fixed that held me back and working on the rest.
bigblok2000ranger
bigblok2000ranger
Post  richter69 October 10th 2012, 3:54 pm
those electric smog pumps dont pull much vac at all, like 4-5" max.
moroso 3 vane still going strong on mine after 10 plus years..............
Post  bruno October 10th 2012, 4:08 pm
richter69 wrote:those electric smog pumps dont pull much vac at all, like 4-5" max.
x2 .... got some bad advise and thru both of those electric deals in the garbage
Oakley Motorsports set me up with this
https://www.429-460.com/t13307-vacuum-pump?highlight=vacuum
http://WWW.CKRME.COM
Post  richter69 October 10th 2012, 5:19 pm
the electric pumps work good to remove moisture from an alky motor but thats about it.
Post  quick 52 October 10th 2012, 6:14 pm
ive been running the same combo for 4 years i running 11.40s to 11.70s would like to run 11.20s to 11.50s. think its doable with a few tweets new tires taller going to have the valves cut back new valve springs remove swaybar on front if that not working ill spray a 25hp hit
quick 52
