460 street/pull
460 street/pull Empty 460 street/pull
Post  PARCLAY October 9th 2012, 6:19 pm
This is my first built i want 500 to 550hp with a lot of torque at around 4,500 rpms. i have a 460 block bored 30 over.I want to use aluminum heads. Does anyone have any ideas what the best stroke,heads,cam,crank to use would be. this truck does not get driven much but i still want to run pump gas and pull in a stock class. Again its my first and thanks for any help or comments.
PARCLAY
460 street/pull Empty Re: 460 street/pull
Post  4604X4 October 11th 2012, 2:06 pm
You're goals sound a lot like mine. See my post on the TFS 290 heads.
Basically I think you will want/need a stroker kit (521 to 557 CID) to achieve the HP and TQ desired at a low enough rpm while keeping some street manners.
4604X4
4604X4
Post  PARCLAY October 11th 2012, 2:27 pm
Thanks a lot Where can i find it?
PARCLAY
Post  IDIeselman October 11th 2012, 6:50 pm
IDIeselman
IDIeselman
Post  PARCLAY October 12th 2012, 1:38 pm
Thanks Guys
PARCLAY
