Oil usage / Vacuum Pump question
+10
kjett
Wheelie58
56Tbird
psfracer
14 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Oil usage / Vacuum Pump question
baller...........Nevs wrote:Wheelie58 wrote:It is good to hear that you are heading in the right direction.
I am working on a new valve cover design that will have an integral oil separator / baffle chamber in the front.
Give me a call or PM if you want to help shake it down.
Keith
678-458-2033
Keith is a standup guy to say the least! I'd jump at the offer...
Ok, I just wanted to follow up on this thread and state that I moved the fitting from the front of the valve cover to the top (similar to Wheelie58) and I can say the problem is completely gone. I made 6 passes this last Saturday and checked the tank after every 2 passes, and there was only drops of oil coming out (vs 100ml like before!). Very happy about that. Thanks for the suggestions.
Here is a picture--that small square piece of sheetmetal with the rivets is where I had the line for the vacuum pump, and it was sucking up a bunch of oil. I moved it to the top of the same valve cover, everything is fine now. Just for reference.
Have you met Keith? j/k:cheers:Nevs wrote:Keith is a standup guy to say the least! I'd jump at the offer...Wheelie58 wrote:It is good to hear that you are heading in the right direction.
Keith
678-458-2033
342g- BBF CONTRIBUTOR
Page 2 of 2 • 1, 2
» Vacuum Pump Question....
» vacuum pump ?
» vacuum pump?
» vacuum pump
» vacuum pump ?
» vacuum pump?
» vacuum pump
Page 2 of 2
