Engine Assembly
Engine Assembly
Guy's, I need your input on this. I'am selling a used engine assembly to one our friends and forum members, I want to make sure the Dome pistons will work for him. I have used this setup w/2 different head combo's, A429's and DoveC's.His heads will be Edelbrock's . I presume they have close to the same design combustion chambers as the A429's but I want to be sure they will work for him.They are .400 dome Venolia's.
Re: Engine Assembly
Yes Rick they have the same valve pierce points so they will work fine....
the Coug- Posts : 3055
Re: Engine Assembly
They'll work fine but he still should check piston to valve clearance.
D. Sea- Posts : 2768
Re: Engine Assembly
I told him I thought they were the same,but wanted to be sure. Thanks Guy's
» 514ci BLUE THUNDER HEADED ENGINE & bbf parts,and engine for sale
» need info asap on engine combo ( 4.3 vs 4.5 crank) ordering it by tommmorrow details inside of engine plans
» C9VE engine from 69 Continental -- Have questions about where to go with this engine
» ENGINE RPM DROPS & ENGINE DIES AT IDLE & BRAKE PROBLEMS
