Shower for the shop.
+6
Dave C.
10 posters
Shower for the shop. Empty Shower for the shop.
Post  dfree383 Sun 24 Mar - 15:08
My new shop. Has a bath and id like to,add a shower to it, does Anybody have a suggestion or manufacture of a shower for my shop the will work with an above the floor drain? I don't want to dig up the floors and would like to tie it into the sink drain.
Shower for the shop. Empty Re: Shower for the shop.
Post  HorsinAround Sun 24 Mar - 15:17
dfree383 wrote:My new shop. Has a bath and id like to,add a shower to it, does Anybody have a suggestion or manufacture of a shower for my shop the will work with an above the floor drain? I don't want to dig up the floors and would like to tie it into the sink drain.
Can you put a raised floor in?
http://www.frontpagefab.com
Post  Curt Sun 24 Mar - 15:34
You would want to dig at least enough of a hole to put a sump in. Then you could pump it, just like a basement.
Post  Dave C. Sun 24 Mar - 16:39
I'm sure it has been done before....Youtube it!
Dave C.
Post  69F100 Sun 24 Mar - 16:50
Dave how close can you get it to the sink rase it off the floor enough to run your drain to the sink and build a cover to go over the pipe along the bottom of the wall.You can get a fiberglass shower from lowes or home depo.We have did this in cargo trailers to get to the tank under the floor.
You could use something like this.
http://www.lowes.com/Bathroom/Showers-Shower-Accessories/Showers-Shower-Kits/_/N-1z0x7zq/pl?goToProdList=true&Ns=p_product_avg_rating|1
Post  richter69 Sun 24 Mar - 16:54
I just shower in the house.
Post  rmcomprandy Sun 24 Mar - 16:57
YES ... I have a friend with his shop shower raised 8 inches and a plastic square tub under it with a boat bilge pump for evacuation.
Post  Dave Maxwell Sun 24 Mar - 16:59
Like this idea. I stubbed in drains before pour but didn't think of shower. I have to walk across carpet to get to my house shower or bathroom. I might look into it after I get bathroom started
Dave Maxwell
Post  jeffgfg Mon 25 Mar - 11:09
There are showers that have a sump built in with a pump and you just need to tie them into a 1 1/2" drain line. Check for basement showers or below grade shower. They even have toilets that do the same thing. I will try and find the name. Any good plumbing supply company should be able to find you one.
jeffgfg
Post  dfree383 Mon 25 Mar - 12:39
That's what I'm looking for.
Can't seem to find anything online.
Post  Dave C. Mon 25 Mar - 16:51
Found a good forum for u ..Terry Love's DIY....look up basement shower...
Dave C.
Post  jeffgfg Mon 25 Mar - 18:16
I am sorry about the information I should have checked before I posted. They do not make these anymore. I guess it was a little farther back than I thought. But... check out Sani-flo.com they have pumps that sit on the floor or behind walls that will pump everything into a 1 1/2" line. You would have to raise the shower base up enough for the drain and an elbow. Some 2x4's and some tile will make it look nice.
jeffgfg
Post  dfree383 Thu 28 Mar - 13:12
bump
Post  72mav Tue 2 Apr - 18:16
Dave,
I just saw a tv commercial for theese. So I assume they still available.
Try the big box stores, home depot etc.
72mav
72mav
