piston clearance in bore?
I know that .004 is normal bore clearance,
But, I have a motor with 4.390 pistons and it has file fit rings. All out race only engine... 12.50:1 compression
Will it be ok with .007 to .008 piston clearance?????
what do you guys think, Thanks
racinghabbit- Posts : 575
Re: piston clearance in bore?
loose is fast ! as long as its a race engine and they are forged it will work.
Until you reach "excessive" loose is better than tight imo.
Hell I use to run .010 back in the day but they have better pistons now. run it
res0rli9- BBF CONTRIBUTOR
My 460 I had in my Ranger I ran them loose it needs boring but I put a new set of cheapo speed pro flat tops in it and bought a set of over sized ring and cut them to fit and ran it turning it 6500 rpm.
» Looking for 4.450 bore piston ring package?
» IDT's new 1400-1500 heads?
» Cometic 4.400 bore gaskets on 4.390 bore block ,will it work ?
» Anyone know how close the Forged L2366f piston is to cast 429 piston?
» 4.600 bore
» 4.600 bore
