hyper piston ring gap
I was reading a thread on ring gap for hypereutectic pistons and can't find it now. Can't remember if it was on this forum or the 'other' BBF forum. Bought a 468 to refresh w/KB 137 pistons and want to make sure of the ring gap. I believe .030 gap for the top ring was what was decided on. Pistons are flattop w/ one valve relief, .032 on hole and D3 heads.
GT300TD- BBF CONTRIBUTOR
Re: hyper piston ring gap
On KB piston check with them I know when i was cutting my rings for my KB forged paper work from kb called for .004 than my rings called for.
Definatly check with KB, hypers, because the piston absorbs less heat something with the amount of silica in the material, push more heat into the ring. This coupled with a very "brittle" material means hypers require more ring gap in comparable bores than high performance forged, and way more than comparable builds with standard stock pieces.
kim- Posts : 700
» piston ring choice and preferred ring seat/breakin time ?
» piston ring compressor
» PISTON RING QUESTION
» Looking for 4.450 bore piston ring package?
» The question of the day piston ring
