TFS 18 Bolt heads 360cc
CHARLIEB
Hello I am almost done buying all the parts I need for my 598ci pump gas motor. What I am looking for is set of Trick Flow 360cc heads. I am looking for 2.400 intake and 1.880 exhaust. I will need to have the spring changed out to a lighter spring opening for street use. The soild roller cam that I am thinking for my build requires the springs to be at 450 lbs. I hope charlie,lem or oakley will chime in
CHARLIEB- Posts : 145
Re: TFS 18 Bolt heads 360cc
just give Phillip or Lem a call and get them from him .....
CHARLIEB wrote:Hello I am almost done buying all the parts I need for my 598ci pump gas motor. What I am looking for is set of Trick Flow 360cc heads. I am looking for 2.400 intake and 1.880 exhaust. I will need to have the spring changed out to a lighter spring opening for street use. The soild roller cam that I am thinking for my build requires the springs to be at 450 lbs. I hope charlie,lem or oakley will chime in
450 lbs. open aint much for a valve that heavy.....email a phone # I'd be glad to work with you on the project.
Damn that is a quick response....keep that in mind on my next engine purchase.Lem Evans wrote:CHARLIEB wrote:Hello I am almost done buying all the parts I need for my 598ci pump gas motor. What I am looking for is set of Trick Flow 360cc heads. I am looking for 2.400 intake and 1.880 exhaust. I will need to have the spring changed out to a lighter spring opening for street use. The soild roller cam that I am thinking for my build requires the springs to be at 450 lbs. I hope charlie,lem or oakley will chime in
70FB- BBF CONTRIBUTOR
450 lbs. open aint much for a valve that heavy.....email a phone # I'd be glad to work with you on the project.[/quote]Damn that is a quick response....keep that in mind on my next engine purchase.[/quote]
Lems customer service and Charm is WHY we all recommend BFEvansRaceParts.com.
Here is the part number for the Comp Cam roller camshaft 34-779-9 grind number is XR274r-10 maybe this will help.
I have everything except the heads, pistons, camshaft and push rods
Damn that is a quick response....keep that in mind on my next engine purchase.[/quote]bbf-falcon wrote:450 lbs. open aint much for a valve that heavy.....email a phone # I'd be glad to work with you on the project.
Lems customer service and Charm is WHY we all recommend BFEvansRaceParts.com. [/quote]
LOL! Lem sugar coats everything
chuck- Posts : 414
» Trick Flow A460 360cc heads cnc flow numbers
» 18 bolt heads
» tfs a460 18 bolt heads
» 10 bolt A460 Heads
» 18 bolt heads
