Disc - Drum Master Cyl ?
Whats a good master cyl that will work with disc on front and drum on rear, For a 95 mustang ? Have a Strange Engineering B3359, but brakes are real hard...
colormebad- Posts : 262
Re: Disc - Drum Master Cyl ?
Does your master require the pedal ratio to be changed? I bought one for an 85 Ranger from Advance posted in this thread
https://www.429-460.com/t16613p15-bbf-fox-need-info-on-manual-master-cylinder
I have the UPR adapter to mount it. I have not installed mine yet though.
bigblok2000ranger wrote:Does your master require the pedal ratio to be changed? I bought one for an 85 Ranger from Advance posted in this thread
I drilled the hole up higher like the instructions said..
using the correct rod?
I took mine back off it didnt work on mine I disnt have enough stopping power i went and got one for a 95 dodge d150 with man brakea
I just used a manual master from a 1979 manual brake equipped Mustang. It's not as pretty as the aluminum ones, but has a nice feel for braking and stops good!
Gary
Gary
GTmustang- BBF CONTRIBUTOR
dfree383 wrote:using the correct rod?
Using the rod that came with the kit
All the ranger ones i pull up, doen't show to be aluminum
hoses and calipers / cylinders all good?
What pads and shoes? they broke in correctly?
Pinched Line somewhere?
What are you expecting it to feel like? If you compairing it to a new car its not going to feel the same? Have you had manual brakes before?
dfree383 wrote:hoses and calipers / cylinders all good?
I have the aerospace brake kit up front..All brake parts including lines/cylinders are all new...I have ran manual brakes lots of times, but never had brakes this hard...On some of my other cars i used a M/S off a 76 ford F100 and had real good brakes & the best one was for a pinto, but can't remember the year...
I've had issues with pads making it hard to stop in the past.
I drilled a hole on the brake pedal lever itself 1” above the existing stock location like instruction's said...I just got through rechecking it...Think its the wrong M/S for disc/drum brakes
whats the diameter on the piston?
dfree383 wrote:whats the diameter on the piston?
Here is the one i have installed...
http://www.jegs.com/i/Strange-Engineering/873/B3359/10002/-1
I just called strange & they said do away with the p/p valve and use an adj valve for the rear and a T..I read somewhere you could gut the stock p/p valve ...Anyone have any info on this ?
colormebad wrote:bigblok2000ranger wrote:Does your master require the pedal ratio to be changed? I bought one for an 85 Ranger from Advance posted in this thread
The part number I gave in the link is an aluminum unit, it is identical to a cast unit but aluminum it does not require a proportioning valve.
Jim that is strange Rich is using one on his car and works great. And his car ids write a bit faster than either one of ours.
bigblok2000ranger wrote:colormebad wrote:bigblok2000ranger wrote:Does your master require the pedal ratio to be changed? I bought one for an 85 Ranger from Advance posted in this thread
It might have been just a bad not saying they are not any good it just didnt work on mine. Rick and me worked on them I changed the ratio on the padel and everything I tried didnt help I had my belley full of the problem with brakes and went and bought the mopar like the strange unit and put on now I have brakes again. I still have it in the barn.
Maybe I noticed from your pics yours was definitely a reman where mine looks to be a new unit.
bigblok2000ranger wrote:Maybe I noticed from your pics yours was definitely a reman where mine looks to be a new unit.
Mine was brand new from Skinny Kid...I took the end plug out earlier & removed the spring/o-ring/plunger...Then drilled and tapped the end plug and installed a 1/8" pipe plug with red loctite...Brake will go down more now and doesn't feel real hard, but will have to back it out and test it tomorrow...I will have to order an adj p/p valve for the rear drums, even though some says you dont need one with this master cyl...
» Drum to disc 1970 Mustang drag car
» Falcon front drum to disc conversion.
» rear disc for fox
» rear disc for fox
» Disc brake set up for 9''
» rear disc for fox
» rear disc for fox
