Powerglide tailshaft?
bigjohn2007
One of the bolts is striped out on tailshaft.Is a heli coil the only way to fix this problem without changing the tail shaft?
bigjohn2007- BBF CONTRIBUTOR
Re: Powerglide tailshaft?
Maybe not the only way, but probably the best way. Helicoil into aluminum = better than new.
maverick- BBF CONTRIBUTOR
x3maverick wrote:Maybe not the only way, but probably the best way. Helicoil into aluminum = better than new.
agreed....
You might do 'em all while you're in there.
maverick wrote:You might do 'em all while you're in there.
Its the way forward !
austin460- Posts : 79
Doug Rahn wrote:TimeSert over the Helicoil;)
Depends on how badly stripped hole is. If hole is in a bad way might be better off going heli-coil due to greater wall thickness.
» c6 trans tailshaft??????
» Snap C6 tailshaft
» c6 looking for short tailshaft
» wtb.4x4 c4 output shaft & tailshaft
» BPO Powerglide
» Snap C6 tailshaft
» BPO Powerglide
