C6 no 2nd gear
Page 1 of 2
Page 1 of 2 • 1, 2
C6 no 2nd gear
I finally got some time to try to race and realized I don't have 2nd gear. Tranny was fully rebuilt and I put it in to use and when I shift manually there isn't a 2nd gear.
This is a reverse shift tranny with Frank Merkyl's valve body. I emailed Frank but I bet hes busy on the farm, haven't heard back from him yet.
Any ideas?? Valve Body issue? or something mechanical in the tranny?
My tranny guy has cancer and had surgery so I really don't want to bother him.
Thanks Tore
Thanks Tore
Tore- Posts : 865
Re: C6 no 2nd gear
Does it have 1st and 3rd ??
If it does, check the "wedge" that tightens the band, it may have back off or fallen out..
Don't ask how I know....
QtrWarrior- Posts : 2703
Re: C6 no 2nd gear
Tore wrote:I finally got some time to try to race and realized I don't have 2nd gear. Tranny was fully rebuilt and I put it in to use and when I shift manually there isn't a 2nd gear.
Thanks Tore
Check the Band band Adjustment , servo !
Do you have 3rd gear ? Your second gear isn't there at all ?
whitefield- Posts : 2244
Re: C6 no 2nd gear
I have 3rd gear but no 2nd at all.
Are you talking about the servo on the side of the tranny?
Tore
Tore
Tore- Posts : 865
Re: C6 no 2nd gear
QtrWarrior wrote:Does it have 1st and 3rd ??
Where is the wedge located at? I have no experience in working on trannies .
Tore
Tore- Posts : 865
Re: C6 no 2nd gear
Tore wrote:I have 3rd gear but no 2nd at all.
Tore
Yes Thats what applies the band for second gear
Re: C6 no 2nd gear
You will have to drop the VB to see the wedge . Might be a good Idea to drop the valve body and air check the servo !
Re: C6 no 2nd gear
Here is a link that might help some!
http://www.fourdoorbronco.com/board/showthread.php?3652-Removal-Rebuilding-and-Installation-of-a-Ford-C6-Transmission-Pictorial-Reference
Re: C6 no 2nd gear
Is it a stock or aftermarkt servo ?
Re: C6 no 2nd gear
whitefield wrote:Is it a stock or aftermarkt servo ?
After market.
This tranny was one I used a few years ago and it worked great. I pulled it to freshen up.no new parts.
Tore
Tore- Posts : 865
Re: C6 no 2nd gear
Tore wrote:whitefield wrote:Is it a stock or aftermarkt servo ?
After market.
Tore
If the servo and everything air checks with a good thump then I would see what Frank has to say! I would also drop the VB just to air check and see if the wedge fell out .
Re: C6 no 2nd gear
I will be wrenching this weekend it looks like.
Thanks for the help.
Tore
Tore
Tore- Posts : 865
Re: C6 no 2nd gear
Tore wrote:I will be wrenching this weekend it looks like.
Tore
Your Welcome !
Let us know what you Find ?
Air checking servo
On a c6 To air check the servo you need to remove the valve body .Hopefully when you do this you will find the wedge has fallen out and you wont need to air check the servo .You will need to get a picture of a c6 trans. that explains where the locations are to air check .There are two locations one applies the band and the other takes the band off .You need a long thin air nozzel i found mine at walmart .And when you do this get ready for a trans fluid bath!! I have built several c6s and the only time I have problems with the second gear shift is when I went with that damn sonnax servo .If you do a search there is a lot of sonnax servo problems on there mine included .Mr. Merkl has a fix for that servo and it works .Maybe your wedges somehow came out or the band is bad what ever it is we will try to help you .And if the band applies with air and isnt toast something in your valve body is the problem .If you cant get any one to help you give me a call 678 603 8400 .I am not a professional trans. builder just a pretty good backyard mechanic .Doug
manofmerc- BBF CONTRIBUTOR
Re: C6 no 2nd gear
After reading this we might have swapped out the Servo ,I really can't remember if we did for another tranny. Its been so long.
Wheres the fix for the Sonnex servo is that's what I have?
Tore
Tore
Tore- Posts : 865
Re: C6 no 2nd gear
Well I pulled the servo and I had to wiggle it out with 2 screwdrivers. It was tight. Off to the lathe.
Tore- Posts : 865
Re: C6 no 2nd gear
manofmerc wrote:On a c6 To air check the servo you need to remove the valve body .Hopefully when you do this you will find the wedge has fallen out and you wont need to air check the servo .You will need to get a picture of a c6 trans. that explains where the locations are to air check .There are two locations one applies the band and the other takes the band off .You need a long thin air nozzel i found mine at walmart .And when you do this get ready for a trans fluid bath!! I have built several c6s and the only time I have problems with the second gear shift is when I went with that damn sonnax servo .If you do a search there is a lot of sonnax servo problems on there mine included .Mr. Merkl has a fix for that servo and it works .Maybe your wedges somehow came out or the band is bad what ever it is we will try to help you .And if the band applies with air and isnt toast something in your valve body is the problem .If you cant get any one to help you give me a call 678 603 8400 .I am not a professional trans. builder just a pretty good backyard mechanic .Doug
Doug,
Whens a good time to call you I have a couple questions.
Tore
Tore- Posts : 865
Re: C6 no 2nd gear
http://www.460ford.com/forum/search.php?searchid=2901602
Here you go , info from Franks is here , cut the groove .007" deeper .
Gregaust- Posts : 625
Re: C6 no 2nd gear
Well I remachined the Sonnax Servo per Frank's spec and that didn't help. Drove it up and down the road no difference. So if I get a chance this week I will drop the valvebody and see if the wedges fell out.
Special thanks to Monomerc for answering a few question I had on this deal. called him on the ph and he was very helpful.
Thanks Tore
Thanks Tore
Tore- Posts : 865
Re: C6 no 2nd gear
Tore wrote:Well I remachined the Sonnax Servo per Frank's spec and that didn't help. Drove it up and down the road no difference. So if I get a chance this week I will drop the valvebody and see if the wedges fell out.
Thanks Tore
So did you get it to slide in and out smooth and with little drag ?
When you drop the Vb air check it before you put it back together. Goodluck
Re: C6 no 2nd gear
Never tried the air thing. Going to try to pull the valve body sometime this week.
Tore
Tore
Tore- Posts : 865
Page 1 of 2 • 1, 2
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» 29x10.5 w tire ,1.80 first gear glide, nitrous , wanting 6800-7000rpm thru traps ...what gear roughly???
» Pro Stock Trans gear ratio / Rear Gear
» 460 rotor gear connecting gear bad
Page 1 of 2
