Gear Lube Suggestions
+6
zrob90sc
Dave C.
bigblockfox468
10 posters
Gear Lube Suggestions Empty Gear Lube Suggestions
Post  bigblockfox468 July 11th 2013, 7:49 am
Anything special? I have an 8.8 with a spool w/4:10's..........drag application.
bigblockfox468
bigblockfox468
Gear Lube Suggestions Empty Re: Gear Lube Suggestions
Post  whatbumper July 11th 2013, 9:47 am
I've ran everything and have settled on the regular automotive stuff from Amsoil. We ran some of the "race" stuff from various companies and the gear wear was very noticeably more than with Amsoil stuff. I've had almost every major brand of stuff in cars and racecars over the years and this is the only one I run in everything now.
http://www.amsoil.com/shop/by-product/gear-lube/severe-gear-75w-90/?code=SVGQT-EA
Post  bigblockfox468 July 11th 2013, 9:59 am
whatbumper wrote:I've ran everything and have settled on the regular automotive stuff from Amsoil.  We ran some of the "race" stuff from various companies and the gear wear was very noticeably more than with Amsoil stuff.  I've had almost every major brand of stuff in cars and racecars over the years and this is the only one I run in everything now.
Thanks! Any ideas on the capacity?
bigblockfox468
bigblockfox468
Post  richter69 July 11th 2013, 11:10 am
I use the motorcraft 75-140 synthetic, I get it free from work so im biased.
should take 2-2.5 quarts
Post  Dave C. July 11th 2013, 12:48 pm
KY for the win!cheers
Dave C.
Post  whatbumper July 11th 2013, 1:04 pm
richter69 wrote:I use the motorcraft 75-140 synthetic, I get it free from work so im biased.
You have a hell of a sponsor though. Lol
Post  bbf-falcon July 11th 2013, 11:33 pm
Syn. is some NASTY shit too get up from a race track. Was at our local track one night, when a PrpMod car was there doing some testing. Scattered a centersection all over the track. That was it for the rest of us. They had to call experts in the next week to get the track back in shape.Evil or Very Mad
Post  zrob90sc July 13th 2013, 1:17 pm
Any thoughts on straight 50w chevron synthetic? I've got buckets of this stuff. We use it for transmissions in our big rigs.
zrob90sc
zrob90sc
Post  bigblok2000ranger July 14th 2013, 5:45 pm
My rear end guy advises against synthetics for drag racing because he says the rearend does not usually getup enough heat for them to work correctly and the standard dinosaur oil does not need the heat to work properly.
I use Coastal 80/90 last couple years with no issues.
bigblok2000ranger
bigblok2000ranger
Post  whatbumper July 14th 2013, 7:46 pm
bigblok2000ranger wrote:My rear end guy advises against synthetics for drag racing because he says the rearend does not usually getup enough heat for them to work correctly and the standard dinosaur oil does not need the heat to work properly.
That's some false info there.
Post  richter69 July 14th 2013, 9:28 pm
with the lower heat the syn would be better...........
you need some good slick stuff between that ring and pinion, its under a severe load when you mash the loud pedal.
Post  bbf-falcon July 15th 2013, 3:13 pm
What is there NOT to work correctly w/Spool/ring/pinion?
Gear Lube Suggestions Empty I like the richmond
Post  manofmerc July 17th 2013, 6:45 am
I have been using richmond brand (same as the ring and pinion ) in my 67 comet bracket car it is a synthetic 95-140 $22 a quart .My local speed shop in Atl. has valvoline synthetic 95-140 for $69.70 a case of 12 I plan to pickup a case today .For everyone information its Barnett performance Probably better to call 404 522 1320 ask for Chuck
manofmerc
Post  DILLIGASDAVE July 17th 2013, 7:45 am
I would have to disagree with that depending on what gear material was used on a drag car. The rock hard factory gears that can go 100K - 200K street miles might be OK with the dino-oil. But when the aftermarket 8620 gear & super soft 9310 nickel pro gears see decent power numbers, your best bet is the synthetic stuff. Hell even the Walmart synthetic stuff is a half-way decent synthetic gear lube.
And as far as rear end temp goes, a smart drag racer will warm the cold trans & rear end before the first pass of the day, and not just warm only the engine.
Post  bigblok2000ranger July 17th 2013, 7:53 am
Seems I have been given some misinformation, he stated that the synthetic needed to get up to~150° to have the proper shear strength.
bigblok2000ranger
bigblok2000ranger
Post  kjett July 17th 2013, 9:12 am
I run the Torco gear lube in both ends of my ranger, and I only run 200' at a time Cool
kjett
kjett
Post  whatbumper July 17th 2013, 10:28 pm
bigblok2000ranger wrote:Seems I have been given some misinformation, he stated that the synthetic needed to get up to~150° to have the proper shear strength.
That's the reason to run synthetics. It doesn't have to have temp to be good. But it is a pain in the rear to get off of the assembly when changing gears and stuff.
