Rod Bearings ???
+10
kim
Dave C.
BradB
HELI-ARC
14 posters
Page 2 of 2 Previous  1, 2
Rod Bearings ???  - Page 2 Empty Re: Rod Bearings ???
Post  Lem Evans August 7th 2013, 7:59 pm
Smile
Post  zrob90sc August 7th 2013, 8:06 pm
Did the rest of the upper bearings still fit snug in the rods? When I spun a rod bearing due to detonation most of the upper rod bearings got hammered and lost their "crush". They basically fell out of the rod during disassembly.
zrob90sc
zrob90sc
Post  maverick August 7th 2013, 8:08 pm
69F100 wrote:
Here is the Hillbilly way to check the plug wires for 'leaks'. Wait untill the sun goes down...raise the hood...put a little heat in the engine...Put the engine on the trans. or foot brake and see if you have 'light show'.
It is my opinion that your combination has more ign. timing than it wants. Could be that the timing being locked is making it worse.
What do you have for a spark plug?
  [/quote
Not only the hillbilly but also the redneck way too check plug wires or just grab them 1 by 1 and run your hand up and down them if it bites you you want to do the after dark test.
Those with pacemakers may want to opt for the "light show" method.Shocked
Post  cool40 August 7th 2013, 8:21 pm
  [/quote
i have a msd7 and realy dont like the idea.no pacemaker yet.... Very Happy
Post  maverick August 7th 2013, 8:28 pm
Shocked Yessir.  MSD 7 series WILL make ya turn it loose...and probably pee your pants.
Post  bbf-falcon August 7th 2013, 9:45 pm
I got lit up by a 6al one time. I don't even want too think about a 7.Shocked Shocked Shocked
Post  kim August 8th 2013, 12:08 am
aint just the 7, its the pro power coil. Blaster coil is about 18,000 volts, pro power 48,000
kim
Post  cool40 August 8th 2013, 12:47 am
kim wrote:aint just the 7, its the pro power coil.  Blaster coil is about 18,000 volts, pro power 48,000
a guy told me dont £¥€{ with it,lol. affraid
Post  HELI-ARC August 8th 2013, 7:31 am
So I will try and talk the new guy a work into coming over and checking my wires while she is running Laughing
The first two motors (DOVE heads) had autolite 45, last motor had autolite 25
Was looking at the third motor crank last night the bearing was hammering at BDC
HELI-ARC
Post  Lem Evans August 8th 2013, 10:04 am
I'm not sure what a 25 is but, the 45 are too hot for the application i.m.o.
AR33 or AR32 would be better.
Post  HELI-ARC August 8th 2013, 11:19 am
Ok I will use those next time. Do you have any theories on why its getting hit at BDC? Thats not Making sence to me as a timing or plug issue.
HELI-ARC
Post  zrob90sc August 8th 2013, 11:30 am
Autolite 25 is a hot plug. They are recommended for stock low compression 2v clevelands. Pics of the bearings and crank would help solve the issue.
zrob90sc
zrob90sc
Post  Larry T August 8th 2013, 9:13 pm
HELI-ARC wrote:So while I am getting pictures of the bearing, which the top half is hammered from pre ignition or timing. Has any one ever seen a cross fire condition with these or any wires? Is there a cool way to test for this? As I would like to sort this out on the next build. Just a note when the third motor was running at an idle I did check all the plug boots on the pass side and up the wires bare handed trying to find my intermittent miss and did not get shocked any where. Also like every other motor out there the wires are just draped over the valve cover (trick flow tall cast alum).
Thanks for the input to date Smile
msd makes a in the car tester to test the msd box or distributor.i have seen the tester used to find a problem with an ignition turned out to be a pick up coil in the distributor.in his case the misfire would only show up now and then.
http://www.msdignition.com/info.aspx?taxid=263&taxid2=289
Larry T
Larry T
