Anybody have a MSD Distributor P/N 8755???
61coon
Moodyblues
Long story..........but make it short
Car was running great..................I sent the distributor to MSD to have a new pin and gear installed.
I brought the timing to TDC. Removed the distributor and sent to MSD. They rebuilt the whole thing and sent back to me.
I put the new distributor back in and it misses. It has a dead miss now and Ive done everything from timing, checking compression, everything. The car has a dead miss. The front two cylinders (1 and 5) are not not as hot as the the others and on alky may be getting too much fuel.
Bottom Line: I put the distributor back in the way it came out when the car was running great and nothing should have changed!
Russ Hood
423-718-3279
Russ Hood
423-718-3279
Re: Anybody have a MSD Distributor P/N 8755???
If you are interested,I have a complete crank trigger deal. Dizzy and all the acc.
On another note,Harold sent one back to MSD for rebuild,when he got it back,I put it in my engine and it ran for about 3 min. and the shaft frozeup n the housing and sheared the gear pin. They must have a bunch of apprentice's doing rebuilds.
I have a pro billet 8577. Can you use that?
61coon- Posts : 1824
you just changed the car over to alky a short time ago right?
Is it Injected (direct port) or carb?
If its like mine (Rons Toilet) with line to each runner you might check & make sure EVERYTHING is clean /no trash stuck in the nozzles, jets, etc...
I know it sounds dumb but a clogged nozzle, line , jet will do exactly what you are describing... just sayin.
I know this seems obvious and stupid, but have you triple-checked the firing order from the cap to the plugs? That's one of my favorite things to take for granted.
maverick- BBF CONTRIBUTOR
Yep that is the one61coon wrote:I have a pro billet 8577. Can you use that?
Lol, yep same here. Yeah I've checked it many times since satmaverick wrote:I know this seems obvious and stupid, but have you triple-checked the firing order from the cap to the plugs? That's one of my favorite things to take for granted.
Ok I haven't checked that, Ty's I will give that a check69bluehotrod wrote:you just changed the car over to alky a short time ago right?
You can run over and get this one if you want to.Moodyblues wrote:Yep that is the one61coon wrote:I have a pro billet 8577. Can you use that?
Thanks Red. I am headed to Indy to do the bucket list, had my tix for a while. Can I come by Sunday evening?61coon wrote:You can run over and get this one if you want to.Moodyblues wrote:Yep that is the one61coon wrote:I have a pro billet 8577. Can you use that?
Thanks bro
Absolutely. I'll text you where I'll leave it. I may not be home.
Thanks a bunch61coon wrote:Absolutely. I'll text you where I'll leave it. I may not be home.
should hide like a buncha notes..... scavenger hunt at Reds.........
I may be home by 6:51.... Dove shoot at snake's place Monday.richter69 wrote:should hide like a buncha notes..... scavenger hunt at Reds.........
perfect.....
Sounds like a custom deal.
Dave C.- Posts : 1268
» MSD Distributor to replace Duraspark Distributor?
» stock distributor vs msd distributor
» Crank trigger question
» What Distributor
» msd distributor in 460 block
» What Distributor
