429 460 distributor
429 460 distributor
Just noticed the tag on my distributor. D9TE 12127, kinda looks cadywampus. My block is a D0VE-A, the heads are both D0VE-C and the intake manifold is D0VE 9425-B. I have not checked the crank but I think this is a 429 from a torino.
I've done some research and found that the distributor is from a 351/390. The truck runs fine. But I'm wondering if it will cause future problems?
bigblackbronco- Posts : 13
Re: 429 460 distributor
Don't worry about the looks,thats just the way they are,they tend to tilt to the passenger side abit. 351C/mod/400/and 429/460 will interchange. 351w are different. 332/352/390/427/428 are in the FE family .They WILL NOT interchange to the 385 series.
big thanks
Just changed the water pump today and noticed that. Thanks for the info.
A 351W distributor will fit but needs the 460 gear installed at the correct height.
jbozzelle- Posts : 3705
429/460 distributor
i think winsor and FE motors have1/4" hex oil pump drives, while cleveland and 429/460 motors have 5/16" hex drive, so check before swapping !!
werneil- Posts : 12
351W are the same hex as the BBF.werneil wrote:i think winsor and FE motors have1/4" hex oil pump drives, while cleveland and 429/460 motors have 5/16" hex drive, so check before swapping !!
» MSD Distributor to replace Duraspark Distributor?
» stock distributor vs msd distributor
» Crank trigger question
» What Distributor
» msd distributor in 460 block
» What Distributor
