higher rpm but same et
+9
bosshoss
whitefield
61coon
johndickjr
13 posters
Page 2 of 2 Previous  1, 2
higher rpm but same et - Page 2 Empty Re: higher rpm but same et
Post  richter69 September 13th 2013, 8:12 pm
how much more?
Post  whitefield September 13th 2013, 9:32 pm
johndickjr wrote:New motor is will be way more motor then whats in it now
Unless it is a big block making 650 plus hp or a large cubic inch small block making 750 or more n/a the c4 will be just fine !IMO:)
whitefield
whitefield
Post  johndickjr September 13th 2013, 9:43 pm
If i do it 427 sbf 13-1 ..super vic intake ..depends on funds
johndickjr
Post  johndickjr September 13th 2013, 9:46 pm
If not ive got some decent piston for a 302 to bump this motor to 13-1 its around 10-1 right now..and try better intake
johndickjr
Post  whitefield September 13th 2013, 9:51 pm
johndickjr wrote:If i do it 427 sbf  13-1 ..super vic intake ..depends on funds
That's my next engine !Cool
Current engine is a 10.5:1 393W 3000lb running a c-4 5000 stall raced and street driven.
whitefield
whitefield
Post  richter69 September 13th 2013, 11:36 pm
Id keep the c4, unless the 427 is on spray.
Post  Mark Miller September 14th 2013, 1:39 am
richter69 wrote:Id keep the c4, unless the 427 is on spray.
Jon,i think he has a really light car with a 8 or 9" wide tire maybe that's why he was thinking glide?
Later Mark.
Post  dfree383 September 14th 2013, 1:47 am
johndickjr wrote:If not ive got some decent  piston for a 302 to bump this motor to 13-1 its around 10-1 right now..and try better intake
stick with the C4 if you go this route.
I you do a big windsor on the small tire the glide could be a better choice for bracket racing.
Post  QtrWarrior September 14th 2013, 7:02 am
X2 or is it 3..
QtrWarrior
QtrWarrior
Post  richter69 September 14th 2013, 10:18 am
my sb car is pretty light and runs on a small tire, its a heads up car. but prints slips like a copy machine. You could gear it to not hit so hard down low also. Im all about powerglides but everything has its place. the money spent on the glide conversion would buy some parts for the C4 and make it more reliable than what he has..
Post  johndickjr September 14th 2013, 10:52 am
Currently on 26x8.5 tires car weighs 2400 lbs 100% bracket car
johndickjr
Post  69F100 September 14th 2013, 1:13 pm
they are a lot more than just building a pg and sticking it in when you start converting one to a pg. I am getting ready to convert my Ranger to a pg and they are a lot more that goes with it than just having a trans built and stick it in.
Stick with the c4 if it been working good for you just get it rebuilt with the good stuff in it and put it back in.
Post  whitefield September 14th 2013, 2:13 pm
johndickjr wrote:Currently on 26x8.5 tires car weighs 2400 lbs 100% bracket car
C4 can be made to handle a lot of power in that light of a Vehicle and be consistent.
Let me know if you want to sale the c4 ?
With the bigger motor or if you are planning on adding more power with this combo, I would choose a 3.50 rear gear ratio and a stall that will make the car work harder in 2nd gear and 3rd gear. Even with a glide making more power on that size tire its going to have to have some good suspension.! My vote is for the c4 now and power glide later on with bigger engine
Here is a stick car video on 8.5 slicks running 10.90s
https://www.youtube.com/watch?v=Or94lVcxG6g
whitefield
whitefield
Post  johndickjr September 14th 2013, 3:28 pm
3.50 gear..you do realize its a 302
johndickjr
Post  johndickjr September 14th 2013, 5:02 pm
Few weeks ago i forgot to put tranny back in 1st gear and left in 2nd gear..60 ft was 1\2 tentH off from normal and et was 10tenth slower..thats with a 1.46 i think it is for 2nd gear in a c4
johndickjr
Post  whitefield September 15th 2013, 12:09 am
johndickjr wrote:3.50 gear..you do realize its a 302
Yes I Do , I was talking about running the 3.50 gear if you was going to stroke the 302 or add NOS to it or put the 427w in N/A . sorry didn't mean to put you in the wrong direction:oops:
whitefield
whitefield
Post  IDT-572 September 17th 2013, 4:01 pm
Any combo with an engine that has low torque and high hp will benefit from a three speed trans.
A good 302 with 450 hp will have around 100 less ft lb of torque. Keeping that little engine in the sweet spot of the power curve will make a faster race car. This helps even more if you cant get the weight down.
You get more mechanical leverage more of the time.
Take a 302 inch engine and make it peak at 9000 rpm and you have a baby prostock needing 5 gears to make it as fast as it could be.
Its all about available power and how you use it.
In this case the C/4 is the trans of choice, it has about the same parasitic loses as a good PG when built right, rollerize it, and a correct converter for the application, plus the optimum rear gear.
JMHO
Post  whatbumper September 17th 2013, 5:29 pm
with 302 based motors I always ran a 4.56 to 4.88 gear with a 28" tire. With the spray maybe a 4.30.
with a bigger inch motor I would go with a 3.89-4.10 gear no matter spray or transmission.
Can't really ever see a need for a 3.50 gear in a race car with a small tire.
I would run a glide due to the fact you are going to a bigger motor in an extremely light car. A very cheap glide would get the job done too. If you have a decent c4 that you can't get rid of then I would stay with it since it's a bracket deal.
Post  whitefield September 17th 2013, 11:17 pm
The reason I suggested the 3.50 gear is I have customer running a small tire 377 CID 3800 stall converter c4 3.50 gear n/a 2800 lbs car and it runs consistent 6.80 @ 100 mph. I also was thinking that he was going with a larger engine and not recomending it for the 302. The Obove time is for 1/8 mile .
whitefield
whitefield
Post  johndickjr September 18th 2013, 6:34 pm
Not trying to outrun anyone..its a bracket car..if its a tad slower with a glide then thats ok..right now im staying c4.. $$ is tight right now had to by wife new vechile only hav 6 months left of my truck may just put new pistons in the 302 bump it to 13-1 and try super victor..piss of some more bbc guys..i love that when they wonder how a 302 ci motor is faster then a 454
johndickjr
Post  69F100 September 19th 2013, 12:52 am
johndickjr wrote:Not trying to outrun anyone..its a bracket car..if its a tad slower with a glide then thats ok..right now im staying c4.. $$ is tight right now had to by wife new vechile  only hav 6 months left of my truck may just put new pistons in the 302 bump it to 13-1 and try super victor..piss of some more bbc guys..i love that when they wonder how a 302 ci motor is faster then a 454
Tell the chevy guys it is because it is a FORD NOT A CHEVY Twisted Evil
Post  whitefield September 21st 2013, 3:58 pm
What you find out was wrong with trans ?
whitefield
whitefield
Post  johndickjr September 22nd 2013, 11:24 am
whitefield wrote:What you find out was wrong with trans ?
have not touched it
johndickjr
Post  johndickjr October 3rd 2013, 1:24 pm
Went out sunday to track..,003 rt..11.65 on a 11.66 dial..but payed a attention to tranny and rpm..it is flaring 500+ rpm from 2-3 shift..its coming out with motor
johndickjr
Post  glenevans January 7th 2014, 7:34 pm
Test
Last edited by glenevans on January 7th 2014, 7:36 pm; edited 2 times in total (Reason for editing : Not pertinent)
glenevans
