Converter Or Carb/Fuel Problem ?
kim
colormebad
I have a friend that has a 408 sbf running nos...When he tested on just motor, it bogs bad off the line through about the 60-80 mark, then runs fine...On nos it leaves like a bullet...In these links its a motor pass , then a nos pass...Track is not prepped good , so he would hook and then break loose...
Motor Pass
https://www.youtube.com/watch?v=xW3dBPGvT84
Nos Pass
https://www.youtube.com/watch?v=l5duIMzOeTk
Motor Pass
Nos Pass
colormebad- Posts : 262
Re: Converter Or Carb/Fuel Problem ?
jet extensions on carb, as well as a bigger squirter/squiter volume. Lean bog.
kim- Posts : 700
kim wrote:jet extensions on carb, as well as a bigger squirter/squiter volume. Lean bog.
Onlything he has done so far is patrick got him to change airbleeds...He changed jets on his own and made no differance..
try a different carb
richter69 wrote:try a different carb
I think some one don't like Pat? lol
Ace
powerstrokeace- Posts : 1496
If the problem is a lack of jet EXTENSIONS (as Kim suggested), simply changing jets won't be much help. Do you know if it actually has extensions in the rear bowl or not?
maverick- BBF CONTRIBUTOR
seems legit.powerstrokeace wrote:I think some one don't like Pat? lolrichter69 wrote:try a different carb
Ace
richter69 wrote:seems legit.powerstrokeace wrote:I think some one don't like Pat? lolrichter69 wrote:try a different carb
Ace
Yes he checked it and it has jet ext's in the back..... Patrick has been trying real hard , getting him to change everything he can think of, just no luck yet...We are trying to find another good carb to try on it....If its dry enough her sat im gona let him put my 1150 on if we dont find a smaller one...
It just never comes into power without the N20.
What converter is in the car? What gear? It might be in the carb, but it could simply be the thing is trying to launch outside the engines power band, and takes that long to come on. The instant 150 hit sure wakes it up, but its going to really spike the torque curve, and that's why its so responsive. Also why it blows the tires off.....
Is there an air cleaner on the carb? If so how tall from top of carb?
TO check if its vent tube slosh, simply connect front and rear vent tubes with some rubber tubeing, put a T in the middle so they can suck air.
kim- Posts : 700
Never thought about vent tube slosh!!!! I will get him to try that sat at the track....No air cleaner....Stall is suppose to be a 5000 PTC......410 Gearkim wrote:It just never comes into power without the N20.
Have you stood behind the car and checked the exhaust to see if it is running rich or watched it launch and see what the tires and suspension are doing ?colormebad wrote:Never thought about vent tube slosh!!!! I will get him to try that sat at the track....No air cleaner....Stall is suppose to be a 5000 PTC......410 Gearkim wrote:It just never comes into power without the N20.
I think the stall is too tight on motor and on the nos. the converter works because it is making more torque
whitefield- Posts : 2244
He didnt have anyone to help him..We gona take a few parts and carbs and try out some new things sat...We talked to Kenny earlier and PTC and found out he only has a 3500 street/street converter...Kenny said he needed a 4500 they make which alot of people run..We gona test this other stuff everyone has mentioned before he changes converterswhitefield wrote:Have you stood behind the car and checked the exhaust to see if it is running rich or watched it launch and see what the tires and suspension are doing ?colormebad wrote:Never thought about vent tube slosh!!!! I will get him to try that sat at the track....No air cleaner....Stall is suppose to be a 5000 PTC......410 Gearkim wrote:It just never comes into power without the N20.
Is the 4500 a 9.5 or 8 ? I ran a 9.5 4800 and then change converters several more times and wound up with a 8 5000 . What is the engine build ?colormebad wrote:He didnt have anyone to help him..We gona take a few parts and carbs and try out some new things sat...We talked to Kenny earlier and PTC and found out he only has a 3500 street/street converter...Kenny said he needed a 4500 they make which alot of people run..We gona test this other stuff everyone has mentioned before he changes converterswhitefield wrote:Have you stood behind the car and checked the exhaust to see if it is running rich or watched it launch and see what the tires and suspension are doing ?colormebad wrote:Never thought about vent tube slosh!!!! I will get him to try that sat at the track....No air cleaner....Stall is suppose to be a 5000 PTC......410 Gearkim wrote:It just never comes into power without the N20.
He was wrong about the converter...He called kenny at PTC and found out its a 3500 strit/strip 3500.. 10"whitefield wrote:Is the 4500 a 9.5 or 8 ? I ran a 9.5 4800 and then change converters several more times and wound up with a 8 5000 . What is the engine build ?colormebad wrote:He didnt have anyone to help him..We gona take a few parts and carbs and try out some new things sat...We talked to Kenny earlier and PTC and found out he only has a 3500 street/street converter...Kenny said he needed a 4500 they make which alot of people run..We gona test this other stuff everyone has mentioned before he changes converterswhitefield wrote:Have you stood behind the car and checked the exhaust to see if it is running rich or watched it launch and see what the tires and suspension are doing ?colormebad wrote:Never thought about vent tube slosh!!!! I will get him to try that sat at the track....No air cleaner....Stall is suppose to be a 5000 PTC......410 Gearkim wrote:It just never comes into power without the N20.
sbf 408 stroker
13:1 compression
C4
410 Gear
Nos
» Now i got a carb problem???
» help carb problem
» fuel pressure regulator problem
» QUICK FUEL CARB ?
» carb -fuel issues
» help carb problem
» QUICK FUEL CARB ?
» carb -fuel issues
