help carb problem
help carb problem
750 edlebrock carb .. runs excellent over half throttle but just off idle stumbles extreamly bad... and at seem like 1/4 throttle is a stumble too... truck idles great and isn't idleing rich at all..
thanks
thanks
bigunitmudracing- Posts : 159
Re: help carb problem
is the vacuum advance on a "live" port? it should'nt be.
bigunitmudracing wrote:750 edlebrock carb .. runs excellent over half throttle but just off idle stumbles extreamly bad... and at seem like 1/4 throttle is a stumble too... truck idles great and isn't idleing rich at all..
thanks
WHICH 750 Edelbrock carb...? The "economy" carb versions will act that way, if the engine isn't completely "stock".
I got a 750 edelbrock too, put it on my maverick. I would go to get on it and she would hesitate, then it would catch up and rev. And that was when it was in park or neutral, I had to ease on it when in gear or she would stall. I couldn't burn rubber. My machinist said that those carbs (not sure on the model) were very hard to tune so we sold it and put the 650 edelbrock back on. Never ran better, I also think it was way too much carb for it when the 750 was on. What size engine is this on anyway and how big of a cam?
bb429power- Posts : 3129
seems like the part numbers were 1406 and 1407 or somthing but what randy said, the street version is lean off idle and thru the lower mid range. the metering springs and rods need to be changed, its easy done and you dont even have to pull the carb apart
jc10000rpm- Posts : 193
» Now i got a carb problem???
» Converter Or Carb/Fuel Problem ?
» weiand carb adapter 4500 carb flange to 4150 intake
» Gas carb v/s Alky carb
» Oil PSI problem
» Oil PSI problem
