Neat 545 Build w/EZ Efi and dyno results
http://www.customclassictrucks.com/techarticles/1210cct_545_ford_engine_build/viewall.html
http://www.customclassictrucks.com/techarticles/1211cct_545_ford_engine_dyno_ez_efi_install/viewall.html
windsor- Posts : 1167
Re: Neat 545 Build w/EZ Efi and dyno results
does the block need machining for clearance with the 4.5 stroke crank?
Tim
Tim
qtrhors1- Posts : 14
NO..qtrhors1 wrote:does the block need machining for clearance with the 4.5 stroke crank?
Tim
res0rli9- BBF CONTRIBUTOR
A 545 with SCJ heads and a 214/224 hydraulic roller cam?
I know its a truck but WTF?
Over.
Over.
TommyK- Posts : 74
yea.....I dug out part one of that build and it has a caption showing how much clearance it has....no need for machining. That means all 429/460 rebuilds that need a crank should get the 4.5 lol
Pretty mild cam it seems for 545 inches(does have .6xx lift). Im so amazed it still made right at 1 hp per inch. That engine should idle like a stock 460. Im curious as to how it would have done with a holley 4150 carb. I love the "stock" look even though I think its sac religious to paint those aluminum heads and intake
Tim
![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif)
Tim
It's for a truck. I think it served its purpose very well.
Killer torque.......................
![Twisted Evil](https://2img.net/i/fa/i/smiles/icon_twisted.gif)
» 557 P-51 BUILD AND DYNO RESULTS
» 557-A429 Bracket Build-Dyno Results
» 598 C heads
» Dyno results: A headed 557 on 91 octane pump gas. DYNO UPDATE page 6
» 582 tfs a460
» 598 C heads
» 582 tfs a460
